I have a 2004 PT Cruiser with an overheating problem. I replaced the Catalytic Converter, Thermostat, Pressure cap (16psi), and have done two radiator flush myself. Now when we replaced the Catalytic Converter it run good for two and a half weeks the through a code. It was running cold, that's when we replaced the thermostat. It run hot so we did a flush and replaced the thermostat again with a fail-safe, Pressure cap (16psi). Now the weird thing is, we can drive it for more then half a day, and then stop at the store go in spend a hour come out head home and it run hot. I know its running hot because its pushing water and coolant back into the over flow tank. I do believe the water pump is working good because I can take the radiator cap off and put my hand over the hole and it will suck my hand down to it not much but if I rev the motor the presser is a lot more.
Have you checked the radiator fan? A known problem with the PT.
when I made it home I left it running and checked and it was running
Maybe radiator is stopped up?
I have considered that, but if it was...Wouldn't it have keep water from coming out when we did the flash?
![]() Quote:
I have looked and have found some for as little as $58 and as much as $130. Is there any thing that needs to be known before going cheap or expensive?
![]() Quote:
Thread Tools | |
Display Modes | |
Help overheating!!! | Kblevins | Tech & Performance Forum | 15 | 10 Aug 2011 02:45 pm |
01 PT overheating | Av8ion | Tech & Performance Forum | 11 | 30 Dec 2009 12:16 am |
PT OVERHEATING!!!PLEASE HELP | mtlhead79 | Tech & Performance Forum | 11 | 28 May 2009 09:21 pm |
Overheating PT! | mikedb | Tech & Performance Forum | 9 | 09 May 2009 04:45 pm |
overheating | missejd1963 | General PT Cruiser Discussions | 3 | 03 May 2009 08:39 pm |
