Questions on possible drum to disk conversion on my vert using parts car.
Old 31 Mar 2012, 09:34 pm
Dill's Avatar
Default Questions on possible drum to disk conversion on my vert using parts car.
With the "siezed" engine pt I have being an all options 01 limited I am looking into the possibility of taking all the greatest things from it and splitting it between my two "nice" pts.
One of the options im playing with is eventually changing the drum brakes on my vert to disk brakes to match my 2002 touring edition.
Are the parking brake cables are the same for a drum brake and disk brake rear axle on a 01 limited and a 05 base vert? Do you think it's easier to swap the entire rear axle assembly or just the disk brake parts if I wanted to?
Old 31 Mar 2012, 09:39 pm
06ptvert's Avatar
Default Re: Questions on possible drum to disk conversion on my vert using parts car.
might be easier to just swap the whole thing...and dont forget to swap the perportioning valve
Old 31 Mar 2012, 10:41 pm
Dill's Avatar
What about the parking brake lines?
Old 31 Mar 2012, 10:47 pm
06ptvert's Avatar
i would use the lines from the disk setup
Old 31 Mar 2012, 10:58 pm
Dill's Avatar
So I cant just take the lines off the drums and attach them to the disks, id have to take out the whole parking brake line and switch them?
Old 31 Mar 2012, 11:03 pm
06ptvert's Avatar
im pretty sure the setup is different(could be wrong) but pretty sure
Old 31 Mar 2012, 11:08 pm
06ptvert's Avatar
also make sure they are both abs or both are not otherwise you will need all that stuff as well
Old 01 Apr 2012, 01:54 pm
UptownSport's Avatar
On Neon (PL Body) you keep spindles and hubs, EVERYTHING else is swapped up to the chassis hard lines.
Many swap to discs on Neon, but they are far too heavy and do nothing on that vehicle- the rotors rust or brake shoes come unglued rather than wear
Old 01 Apr 2012, 04:13 pm
VNT's Avatar
VNT VNT is offline
You would have to swap the lines to the calipers from the junction block at the rear. You could just opt to buy new ones. You would have to swap the backing plates, spindles, adapters for the calipers, bearings, rotors, pads and e-brake shoes and the e-brake cables.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 01 Apr 2012, 05:10 pm
Dill's Avatar
So it seems to be easier to just remove the whole axel, roll it over to the vert and install it then Hook up the lines vs removing every wheel component off both sides right?
Drum brake conversion? Calab Tech & Performance Forum 4 13 Mar 2012 08:51 pm
Some questions about rear disk brakes edb General PT Cruiser Discussions 15 23 Jan 2011 12:41 am
A few questions about parts. fabes89 Turbo Performance 2 23 Jul 2009 06:29 am
F/S Rear Disk Brake Conversion latinkng Classifieds: For Sale/Trade 1 19 Apr 2007 02:31 pm
Rear drum to disc conversion. Can this be done? snakepitt1 Tech & Performance Forum 6 15 Jul 2004 03:09 pm
