3rd Radiator fan motor in 6th months........
Old 31 Mar 2012, 10:29 pm
Exclamation 3rd Radiator fan motor in 6th months........
My 2002 2.4L Limited (N/A) has went through 3 Radiator fan motors in the last 6 months. They are not OEM, i bought them from a local dealer. They honor the warranty, but the last time it stopped workin i overheated to the point i sprung a leak @ my water pump. So replaced the water pump, Timing belt and all that goodness while i was in there. Installed the replacement Rad fan and 2 weeks later the fan was not coming on again. This time when i removed it i noticed that the connecter had gotten hot enough to melt a small part of the plastic inside the connector. This had not happened before.
All new relays ( as of the 2 fan motor ). My question is , Why is this thing going through Fans like candy? Any help would be greatly appreciated.
Thanks in advance.
Old 01 Apr 2012, 06:10 am
chigger_ns's Avatar
Default Re: 3rd Radiator fan motor in 6th months........
I would say you had a bad connector causing all of your problems.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 01 Apr 2012, 02:45 pm
Smile Re: 3rd Radiator fan motor in 6th months........
Thanks chigger_ns, I'll replace that and see I can last longer than a month.
Low Speed Radiator Fan Motor 64fab4 Tech & Performance Forum 3 14 Sep 2011 03:12 pm
Ok radiator fan is 5 months old and half working! invidious Tech & Performance Forum 4 20 Apr 2011 04:02 pm
Changing radiator fan motor 1972cudaguy Tech & Performance Forum 2 28 Mar 2011 07:16 pm
2005 Radiator Fan Motor disco5020 Tech & Performance Forum 5 23 Aug 2009 05:29 pm
