Cruiser Control Issues.
Old 01 Apr 2012, 01:29 pm
Crid's Avatar
Default Cruiser Control Issues.
hi there. i have a 06 cruiser with cruise issues. it worked a while back. and the next time i went to turn it on the cruise like on dash wont light up. wondering if any one has had this issue? and had any tips as to fix it?
2006 Cruiser, Non-Turbo, 19 inch Konig Trouble rims on 225/35/19 Ironman Imove tires, Airaid CAI, E3 Plugs, msd super conductor 8.5 mm wires, Freedon Design Strut Tower Brace, Glow Shift Pillar gauges, EBC Slotted Rotors with EBC Green Stuff Ceramic Fiber Core Pads, Lowerd on Tien springs, Full Custom Kenwood Excelon sound system with 1 12" JL Audio W0, 8000k Blue hids up top and aftermarket OEM Fogs with white 8000k in bumper. Ipcw Bermuda black true led taillights with tinted reverse lights.
Old 01 Apr 2012, 01:32 pm
Default Re: Cruiser Control Issues.
Check your fuses?
Old 01 Apr 2012, 01:43 pm
Crid's Avatar
i have looked i couldn't even locate a fuse for the cruise
Old 01 Apr 2012, 01:48 pm
True. I have the 3 pages of fuses and relays for the 06+ cruisers and unlike the 01-05 PT's you have the new electrics which are quite different and lots of things aren't labeled. Sorry, I have no more help for you except to check the actual hardware (vacuum pump, and wiring) under the hood that make the CC work.
Old 01 Apr 2012, 01:50 pm
Crid's Avatar
ill start there thanks
Old 01 Apr 2012, 01:54 pm
sanatanadharma's Avatar
One sharing from my experience using the cruise control on the highway. I turn it on and find that the word "cruise" on the dash is not on, WTF.
Then I discover the only problem is that my illumination dimmer switch was turned to off and I simply could not see the "cruise".
Posting in stealth is not friendly to this forum.
ABS & Traction Control issues moggyman General PT Cruiser Discussions 3 07 Nov 2011 03:18 pm
01 PT Cruiser starting issues rampagent69 Tech & Performance Forum 1 28 Jun 2011 09:12 am
another pt cruiser with issues. neogeo Tech & Performance Forum 13 04 Jan 2011 06:01 pm
Help Issues With PT Cruiser sml18 Tech & Performance Forum 4 24 May 2010 08:36 pm
Cruiser AC Issues mscaho Tech & Performance Forum 4 16 Jul 2007 11:20 pm
