problem with the radiator fan when I turn the A / C or defrost
  • 1 Post By Chromenut
Old 01 Apr 2012, 04:23 pm
Default problem with the radiator fan when I turn the A / C or defrost
I have Pt Cruiser 2002 and I have a problem with the radiator fan when I turn on A/C or defrost.
When I turn on A/C or Defrost, radiator fan is switched on immediately and includes alternating low and high speed in four of five seconds continuously!
what's the problem?
Old 01 Apr 2012, 06:11 pm
fabreezai's Avatar
Default Re: problem with the radiator fan when I turn the A / C or defrost
what's the problem?
Normal for the fan to kick on when AC or defrost is used, as for the high/lo fluctuating speed not sure. Some one will chime in about it.
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
You already asked me the same question in a private message. Why didn't you wait for an answer which I gave you there?
Old 02 Apr 2012, 12:55 am
I was in the garage and do not manage to resolve defect, Thank you CREVZIN I will try to recharge freon
Old 02 Apr 2012, 04:29 am
I was in the service and found that gas is fine, but that does not have high pressure, and therefore a/c compressor is switched off and on for a few seconds when low pressure rise. compressor is switched on and off alternately, Say that something might be clogged? What can it be?
how to solve the problem?
Old 02 Apr 2012, 06:59 am
If it's clogged, you might have to discharge the whole system, and recharge it. Might be a job for a professional.
Old 02 Apr 2012, 02:14 pm
They did it and the same happens
Old 10 May 2012, 10:59 pm
Guys, I've seen postings time and again about the radiator fans and guesses as to diagnosing the problems, overheating engines, etc. In the OEM Service Manual there is an entire section dedicated to the engine cooling system and how to troubleshoot it. I was going to post this in my library thread but it's locked, so I'll post it individually until Crewzin unlocks it.
Now, the service manuals are different for '06 and up, however if I were you and I was troubleshooting overheating problems, I'd download both because they both have excellent info in them.
Here they are, you can download directly from my web library:
2000-2005 PT Engine Cooling System
& 2006 and up PT Engine Cooling System.
kda66 likes this.
Old 10 May 2012, 11:04 pm
Added to Favorite, thank you Chromey
2006 TURN SIGNAL PROBLEM dj78nc General PT Cruiser Discussions 26 24 May 2015 12:52 pm
Should radiator fan turn on when A/C running? AJAX3222 General PT Cruiser Discussions 11 19 Oct 2011 10:08 am
Very Odd Defrost Switch/Button Problem - Please Help!!! Surf_Blu_Baby General PT Cruiser Discussions 8 22 Sep 2011 03:22 pm
Rear turn signal problem leroy420 General PT Cruiser Discussions 5 18 Feb 2009 09:43 pm
Turn Signal Fuse Problem Indynick General PT Cruiser Discussions 1 04 Jul 2004 07:33 pm
