Low Idle Almost shutting down
Old 03 Apr 2012, 08:29 pm
Default Low Idle Almost shutting down
I have a 2007 PCH Edition. non turbo. The last couple days i have noticed that while i'm stopped my idle is very low. Probably between 8-500 rpm. When the rpm's get around 500 it feels as if its going to die out but then suddenly the rpm's jump around 900 then stabilizes around 800 then slowly back down again. Im noticing a pattern in the idle sequence. This cant be good on the motor.Anyone Have a Idea? Thanks
Old 03 Apr 2012, 08:39 pm
rcktpwrd's Avatar
Default Re: Low Idle Almost shutting down
Try cleaning the throttle body and see if that helps.
Joel
www.rcktpwrd.com
Old 03 Apr 2012, 08:40 pm
You have and (IAC) Idle Air Controller and a (TPS) Throttle Position Sensor, both attached to the Throttle Body. Either one could be bad. Also, a lot of wondering idles are caused by a vacuum leak in one of the hoses. Check around for a bad vacuum line.
Tags
cutting out, idle, low idle, rough
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
please help, car shutting off misslee007 Tech & Performance Forum 4 17 Jun 2011 04:49 pm
Hot AC at idle rick29690 General PT Cruiser Discussions 4 30 May 2010 08:09 am
ruff idle at idle only? KRNFIRE General PT Cruiser Discussions 16 23 Jan 2009 09:08 pm
ac not shutting off rjsmurf Tech & Performance Forum 1 26 Oct 2008 05:21 pm
