MPG: computer vs calculated ???
Old 04 Apr 2012, 10:48 am
Default MPG: computer vs calculated ???
I am just getting dialed in to my new-to-me '06 GT convertible (35K miles)and I am a little confused about the MPG reading on the dash, it seemed quite low. only 23.6 cruising up I-5 for 400 miles (OK I played with the turbo just a little.
So on my last tank, which was mostly normal driving , fairly gentle around town, I reset the trip, reset the mpg computer and filled up at my regular station. After 227.0 miles I returned to the same station and filled up and topped off just like before. My dash computer at this point read 19.9 MPG (It was 20.0 just before I pulled in and waited about 4 minutes in line). I took exactly 10.311 gallons. My math shows that as 22.015 MPG.
Can the computer be 10% low??
Has anyone else made this comparison??
Afterwards I paid attention to my Tripodometer vs the highway mileposts and got a trip reading of 24.3 miles when the milepost showed 25.0, meaning the trip reads 2.8% low, but then I assume the computer and tripodometer are reading the same anyway so it should not effect the relative accuracy. My speedometer reads the same as my GPS.
Phil
Old 04 Apr 2012, 01:22 pm
UptownSport's Avatar
Default Re: MPG: computer vs calculated ???
Tires are much taller than OE?
Old 04 Apr 2012, 02:16 pm
not really, Tires are 235/40R 18. Rotations Per Mile = 795.
Orig. equip is 205/50R 17, R.P.M. = 804
so these are only a slight bit more in circumference.
That was my first thought so I checked the mileposts vs trip. That came out the opposite of what I expected.
...too much math, my head is starting to hurt...
Old 04 Apr 2012, 03:43 pm
cruserdad1976's Avatar
well you will see a lot of guys use "FULLEY" to keep track of mpg's I did for awhile but now i just fill up mu readout and the "REAL" numbers are a lot like yours It will say 21.3 and i will actually be getting 22,5---its close enought for me so i jsut go with it
Old 05 Apr 2012, 12:00 am
Ah, but how big is a gallon? US Liquid, US Dry or Imperial?
The gallon (abbreviation gal)is a measure of volume. Historically it has had many definitions, but there are three definitions in current use: the imperial gallon (≈ 4.546 L) which since metrication is used colloquially in the United Kingdom and semi-officially within Canada, the United States (liquid) gallon (≈ 3.79 L), and the lesser used U.S. dry gallon (≈ 4.40 L). The gallon, be it the imperial or U.S. gallon, is sometimes found in other English-speaking countries.
computer chip or after market computer?? mdskinner731 Tech & Performance Forum 3 08 Nov 2011 02:08 pm
Gas Mileage: Computer versus Calculated? soonercruiser Tech & Performance Forum 7 16 May 2011 07:08 pm
