where is the ECU and how do i remove it?
Old 08 Apr 2012, 06:51 pm
Default where is the ECU and how do i remove it?
i looked around the site and did a search. came up with nothing.
can someone please tell me where the ecu is hiding and how do i remove it?
Old 09 Apr 2012, 06:51 pm
Default Re: where is the ECU and how do i remove it?
NOBODY KNOWS WHERE THE ECU IS??? come on somebody has to know. is it on the firewall behind the air filter?
Old 09 Apr 2012, 06:54 pm
Well, most people are going to view this thread and then ignore it. Why? Well, you don't give any info on the model and/or year of your PT, whether it's a turbo or an NA. Now how can someone answer that question for you without you giving up some info? I make this suggestion over and over and over, ad nauseum. Either post your vehicle info in every thread you start, or even easier, go change your signature block to include what type PT, year, and any mods you have done. That makes it sooooooooooooo much easier for us to help you out.
Okay, off my soap box now....
Old 09 Apr 2012, 07:40 pm
While in 99% of the cases I will totally agree with Chromenut's above post, the problem is that most people call things by the wrong name or unclear of the fact that a lot of the control units are all built into the same square box.
In the PT's case, if your talking the PCM (Power Control Module) or the ECM (Engine Control Module) or the ECU (Electronic Control Unit), it's all the same square silver box that's located against the firewall on the driver side.
Chrysler PT CRUISER Engine Computer ECM PCM ECU Module | eBay
Old 09 Apr 2012, 07:52 pm
compdr59's Avatar
You're too nice. This newbie yells at us in caps without waiting for a response. LOL
Original Owner 135k
Old 09 Apr 2012, 07:58 pm
Your right of course. Not feeling up to par or would have given him heck and not a good answer. Did a little too much today and have a sore chest where my incision is. If it's any consolation, I didn't tell him how to remove it.
...and he did wait EXACTLY (to the minute) 24 hours for a response.
Old 09 Apr 2012, 08:02 pm
There was a whole day in between posts.
Old 09 Apr 2012, 08:20 pm
I would have responded to him yesterday but was so out of it, I drank exactly two Mimosa's and then two Hard Lemonades, and was totally drunk! Yes, I'm a cheap date, considering I've not had a drink in omg I don't know when! So, sat around and vegetated, it was Easter Sunday so I figured I would give the forums a day off....lmao....
Old 09 Apr 2012, 08:55 pm
Medicating were you?
Old 10 Apr 2012, 03:02 am
i figured it was en easy enough question that i did not have to go into specifics. did not mean to get any ones panties in a bunch.
crewzin, thanks for the response. as stated above i researched quite a bit but could not find anything from just reading. i ran across a photo of an engine bay and noticed what i assumed was an ecu mounted on the firewall behind the air filter. i just wanted to make sure that was it.
as for the information of the car it is:
2003 pt cruiser, non turbo, automatic
i figured the ecu was in the same position for all pts.
now the reason for my post was because my car will not start (as in crank over) it still has all electrical functions to include gauges, radio, etc. but i turn the key to start it and nothing happens.
i searched and search and as far as i have read it is one of three things. either a bad ground, the key switch needs to be replaced or the ecu. luckily for me i ordered the key switch a few days before the car decided to stop working since the key kept slipping out of the key hole when the key was turned to the on position.
i am hoping that the problem is simply the key switch or ground. if not, then i will most likely be buying an ecu and just wanted to know where it is to plan ahead.
thanks again crewzin for verifying
How To Remove Front Seats & Remove Or Add Drawer Dill Interior Accessories Forum 20 16 Jul 2014 09:38 am
How do I remove? PTRON Interior Accessories Forum 6 20 Jul 2004 12:28 am
Remove the tag turbomangt Vendors & Buyers Forum 0 02 Sep 2003 10:41 pm
