Sunroof problem 2001
  • 1 Post By irishobo
Old 21 Apr 2012, 08:29 pm
Default Sunroof problem 2001
Hello guys!I recently bought a pt cruiser touring edition 2001 really good condition!The only problem is that the sunroof is going only up and down,not back!So like that i cant enjoy having a sunroof!When i press the A button it goes back 1 inch and then stops!I dont hear any motor working,but i dont think is broken cause its moving even 1 inch!Then i press again the V button and i close the sunroof!
So do you have any suggestions?I read other threads here about sunroof problems but i couldnt find any solution!
Please i would like your help!
Thank you
P.S. Sorry for my English im from Montreal
Old 21 Apr 2012, 08:42 pm
Default Re: Sunroof problem 2001
Did you try giving the sunroof a little help going open with one hand as you hit the button with your other hand?
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 22 Apr 2012, 10:51 am
ew55's Avatar
I have the same issue with mine and found a plastic piece that I guess from the track that broke off. I tried helping it move back but it didn't work. I sometimes just tilt it up but probably should just leave it closed til I fix it. If the sunroof moves at all then I would think it's not the motor so it's the track which is a grand to fix if done at a shop. Would be nice to find a video or something on how to replace the track. Guess I need to look harder.
<2003 Dream Cruiser 2>
Old 22 Apr 2012, 07:38 pm
Hey guys!I didnt try help the sunroof because i dont know what is wrong and i dont want to break something!I tried to find a video how to all over the internet but i cant find nothing!I guess a lot of people have the same problem as me but no one made a how to video!I called chrysler and they dont even know,they told me i should change the whole sunroof(cost a fortune).Anyways guys i hope someone had that before and fixed so he can give us a hand!Thanks
Old 27 Apr 2012, 04:42 pm
Smile Re: Sunroof problem 2001
Check this out Sunroof assembly
I have repaired mine with the kit. It wasn't that hard. Be careful when pulling out the headliner the wires for the lights are glued to it. I just pulled them off the headliner and then hot glued them back on when i was done. Definately easier with two people. One to hold it up, and one to unscrew the screws. The whole assembly will come down in one piece (not that heavy), then just replace the pieces in the assembly with the new ones and reassemble. Good Luck!
ew55 likes this.
2001 Sunroof ptnut General PT Cruiser Discussions 2 27 Mar 2012 05:44 pm
2001 PT Stuck Sunroof Zatharas General PT Cruiser Discussions 1 22 Feb 2012 12:56 am
problem with the sunroof SageNH Tech & Performance Forum 6 16 Oct 2010 12:02 am
Sunroof problem...part for sale?... missingwhatsnear Interior Accessories Forum 0 20 Jul 2009 06:25 pm
2001 radio problem beau526 Sound and Security Forum 3 25 May 2007 12:58 pm
