Engine/Trans swap
Old 04 Jul 2012, 09:09 pm
Default Engine/Trans swap
Read lots of discouraging info on engine swaps from later (06 and up) engines into 01 model PTs. Was wondering if anyone had swapped engine AND transmissions (automatic). If so, would this eliminate some of the problems if the wiring harness and computer were swapped as well...
Old 05 Jul 2012, 02:31 pm
UptownSport's Avatar
Default Re: Engine/Trans swap
You're talking about a daunting task-
Entire powertrain PLUS engine/front harness-
It would seem to be easier/cheaper just to get an '01-02 engine
(Or not wreck it in the first place)
Old 05 Jul 2012, 07:30 pm
Actually, the car is real special to my wife and she loves it! The engine went with 189K on it and I don't want to go to all the trouble/expense of putting in a high mileage 01/02 engine. Thought a later model engine/tranny swap would solve it all...
Old 05 Jul 2012, 07:43 pm
03GTCruiser's Avatar
Not sure how well the 06+ motor and trans would work even with pcm swap as the newer pt are canbus, and the older pt are not.
Not too sure about comparability, just know canbus was the major change between the 2 generations.
Sold 2003 Pt Cruiser GT Autostick. Sold
Now a slow 2009 Pontiac vibe 2.4l 5-speed.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=9656&dateline=1247691  818
227 HP and 281 TQ
new best of 14.56 1/4 mile on 7/25/12 still using the canned tune from my diablosport predator.
*Stage 1, DSP w/93 canned tune, 3" o2 housing, 3" FWDPerformance downpipe with cutout. Bwoody solid mounts. AMX1397 TTAB with K&n drop in filter and airbox mod. AMX1397 lower pipe and AMX1397 uppipe with HKS BOV
* stock nsrt rims powdercoated black, chrome pillars.
* 3 gauge pod w/ aem wideband, Autometer ultralite oil pressure and 30/30 boost, Mopar 8" sub.*
Old 05 Jul 2012, 09:03 pm
Wink Re: Engine/Trans swap
the work you would have to put into this "modification" would not worth the trouble imho. going to CAN bus alone would be daunting.
Try googleing rebuilt PT engines or something to that effect. If you're somewhat mechanically enclined you could just get a rebuilt 01 or 02 long block or short block (depending on your abilities) from someone like "Jasper" or one of the other well known rebuilders and go from there. They do come with a warrenty. This is taking for granted that your tranny is ok and that you don't personally want to teardown and rebuild your existing engine yourself. This way you have an 01 or 02, freshly rebuilt engine that you know will work in your car.
Just a thought.
Jerry
Old 08 Jul 2012, 12:31 am
On second thought, go for it!
Should be able to get everything from a wrecked one!
2.4 engine swap krozby Tech & Performance Forum 15 11 Feb 2016 09:31 pm
ENGINE SWAP jonny Tech & Performance Forum 2 04 Apr 2011 08:49 pm
02 engine swap murphy Tech & Performance Forum 2 11 Dec 2010 12:44 pm
engine swap PTcruzer02 General Turbo Discussions 2 17 Jun 2010 10:01 pm
engine swap INFERNODPPT Tech & Performance Forum 21 29 Oct 2005 10:00 pm
