04' PT In a Coma
Old 11 Jul 2012, 07:56 pm
Default 04' PT In a Coma
Hello guys ,
I've got this same issue on my cruiser that another on here had and cant find a cure. I've been over,under and in between most of the engine bay. My issues started Oct 2011 car shut off like no gas (no codes) ....took to shop replaced fuel pump relay. May 2012 sittin in drive thru and nothing. Car shut off; i didnt notice since a/c was on. Towed it home and it was doin like in the video with no codes.
Took to shop replaced fuel pump relay...again.
After the second time im feelin iffy so its been sittin as i dont wanna get stuck somewhere. Saturday i was tryin to figure it out at home i let it run 2 hrs in the driveway moving wires around etc.. trying to check for grounded wires but nothing, ran fine. An hour later go to move it and it wont start...turns over but nothin past that with No codes. Pulled the fuel pump relay for 15 mins then it starts right up. Later on...wont start so i did key dance and got codes p0685 & p0688. My scanner doesnt "see" any codes but does on my truck. Took the gas cap of and drove to check my scanner Any advice? Today i reset with the battery no start still got p0688 code. Ive got to get it to a shop again or the dealer or ......the junk yard
Any advice is appreciated Thanks
04' na 128k (timing done at 90k) plugs/wires done Jan'12
Old 11 Jul 2012, 08:13 pm
xwing777's Avatar
Default Re: 04' PT In a Coma
Pull your battery out and very closely look at all your cables and the connectors for corrosion. Also while battery is out check the voltage.
Seen this before and was weak battery and bad grounds.
Old 12 Jul 2012, 07:35 pm
I checked the grounds i could find and tried new battery .
Same result. No start code p0688.
Thanks
Old 12 Jul 2012, 08:45 pm
PT_Cuda's Avatar
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Originally Posted by thegooch2 View Post
Hello guys ,
I found this over at the SRT4 forums so its not totally crazy. They are looking at relays. You don't have to be a member to read the thread.
p0685 p0688 asd relay control circuit? - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
I make people mad.. Its what I'm good at..
Old 13 Jul 2012, 11:18 am
I had tried that too !
I'm having it hauled off in a couple hours already called for tow.
I've got an hour or so to decide where to take it.
Shop , dealer, or the dump.
Thanks for your help though.
Old 13 Jul 2012, 12:02 pm
I recommend taking it to a shop that specializes in finding electrical grounding issues.
My dad had a problem in his Chevy that sounded pretty much the same. What it ended up being was the power seats had a ground in it. A specialty tool is required.
I hope you can get an answer.
