Pt cruiser crd 2.2
  #11 (permalink)
Old 30 Jul 2012, 03:09 pm
cruserdad1976's Avatar
Default Re: Pt cruiser crd 2.2
usally crezwin will stead you to a forum that deals with DESIEL PTS we arnt allowed to own them (as much as some of us would love to) I think its a PT forum for Uk
  #12 (permalink)
Old 30 Jul 2012, 03:16 pm
i dont understand what you mean mate lol
  #13 (permalink)
Old 30 Jul 2012, 03:23 pm
Joe,
99% of the people on this forum are from the U.S.A. We are totally familiar with the gasoline 2.4ltr engine but they don't make the diesel on this side of the pond. Your problems could be way different than what we see here. I'll give you what the codes mean but might not anything to do with you engine.
P1130 HO2S Circuit Low Variance Bank 1 Sensor 1 (upstream 02 sensor)
P0100 MAF Sensor Ckt. Insufficient Activity
P0070 Ambient Temperature Sensor Circuit Stuck Conditions
P1685, invalid skim key
P1511 Throttle Control System - Backup System Performance
What I suggest, if it's anything like our, is to take off the negative battery cable for about 5 minutes. Step on the brake peddle to get rid of any residual charge. Put the cable back on and go for a ride. See what codes come up after that.
What Cruiserdad has suggested is that I would suggest for you to visit the United Kingdom site as they are very familiar with the Diesel engine.
http://www.ukcruisers.net/forum/
cruserdad1976 likes this.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
  #14 (permalink)
Old 30 Jul 2012, 03:51 pm
ok so now i know the codes how do i get rid of them if they are there once i take the battery terminal off for 5 mins
  #15 (permalink)
Old 30 Jul 2012, 03:59 pm
well then you have to fix whatever is causing the computor to trip
the codes some times it one thing that will cause several codes to pop up
  #16 (permalink)
Old 31 Jul 2012, 08:02 am
So where can I get a diagram for all the sensors etc
  #17 (permalink)
Old 31 Jul 2012, 08:25 am
Again, you have the diesel that 99% of us don't have. The sensors and things that showed up on your list are different than ours. If you in the UK there's an auto store named Halford's that hopefully they will have a Haynes or Chilton manual dedicated to the diesel engine and you can see all the information, pictures and schematics that you need.
  #18 (permalink)
Old 31 Jul 2012, 09:57 am
I just googled these. there are many reasons you have all these codes, I would start by replacing the O2 Sensors, if diesels have them.
P1130-- The Heated Oxygen Sensor (HO2S) is monitored for switching. (The test fails when the HO2S does not switch due to circuit or fuel at or exceeding a calibrated limit)
P0100 -- MAF Sensor Ckt. Insufficient Activity. (Check the connector for corrosion)(Also could be throwing the code due to another trouble code)
P0070 -- Ambient Temperature Sensor Circuit Stuck Conditions (Check the connector for corrosion)(Also could be throwing the code due to another trouble code)
P1685 --invalid skim key (Does your car have a remote starter?)
P1511 Throttle Control System - Backup System Performance (its a throttle body code. usually requires replacing the throttle body. weak springs is usually the cause)
  #19 (permalink)
Old 31 Jul 2012, 10:57 am
im sure every one would love to help btu we do NOT HAVE desiels over here and Im thinking that the codes are diffrent or at least the issues are
