Recirculate function no worky
Old 02 Aug 2012, 12:31 am
JenneK's Avatar
Default Recirculate function no worky
Anybody have a schematic on whatever actuates the HVAC air intake door?
It appears to be vacuum operated if what I'm looking at behind the glovebox is the correct thing.
Ken posting about his Jenny's car.
01 w/JBA headers, Borla catback, Airaid intake, lowered, purple with shiny wheels.
Old 02 Aug 2012, 03:23 am
Default Re: Recirculate function no worky
Behind the dials in the center console. make sure the vacuum lines and cables all work.
Old 02 Aug 2012, 05:00 am
JenneK's Avatar
Excellent, so it IS vacuum operated. Thanks!
Old 02 Aug 2012, 06:15 am
iirc, the vacuum line for the recirc valve comes directly off of the brake booster vacuum check valve.
edit:i checked my FSM and this is correct for the '03 model.
The valve has 3 ports on it.
1 for the intake manifold
1 for the heater/ac door
1 for the cruise control if installed
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 02 Aug 2012, 02:36 pm
OurPT is correct. The vacuum for the recirc door comes off the brake booster.
Check your vacuum line first. If the actuator itself is bad, it's attached to the heater/ac box inside the dash board. The FSM calls to remove the dash board to access the actuator.
-Chris
Old 02 Aug 2012, 10:23 pm
Does your "recirculate mode" not work in all modes or just in one or two. Just checking to make sure that you knew that if you choose the "MIX" or "DEFROST" modes that the system automatically changes from Recirculation mode to Outside Air mode air for you and the knob will change by itself.
Jerry
Old 02 Aug 2012, 11:24 pm
JenneK's Avatar
I keep it on the "face" setting. Turning the knob has no effect.
Looks like I gotta pull the control panel. The line in the engine compartment is okay and the one at the actuator is intact. I just cannot feel a vacuum pulse when the switch is turned to recirculate.
multi-function switch volcankaw General PT Cruiser Discussions 7 17 Sep 2011 07:10 pm
Multi-Function Lever buckaroobonzai Classifieds: Want To Buy 4 27 Jan 2010 03:16 pm
New Multi Function Switches are In! VOETOM General PT Cruiser Discussions 1 01 Dec 2009 06:13 am
Vacuum line to control vent for outside & recirculate littleblueGT General Turbo Discussions 5 28 Dec 2007 11:04 am
Many Questions on turbo function! dgc333 Turbo Performance 2 09 May 2003 03:36 pm
