vacuum readings and sputter
Old 03 Aug 2012, 07:13 pm
Default vacuum readings and sputter
Good evening, 2001 pt n/a, has had a mis or sputter, changed plugs and wires still there, hooked a vac gage up to throttle body and its 15 in hg with a little needle vibration, when I give it gas it jumps down to 0 then back up. I also noticed under accel my ac vents sound like they move. Does the pt have a vac canister? What should idle vac be? I checked the brake hose with a hand pump and it held as did the hose from the tb hose.
Thank you
Old 03 Aug 2012, 10:25 pm
UptownSport's Avatar
Default Re: vacuum readings and sputter
Vacuums no diff in this engine than any other-
Some guys were gurus with a vacuum gauge- It was the 'scan tool' of yesteryear.
I *think* your vacuum is low, and flutter indicates a miss or a valve.
I though engines would idle at around 20 inches
You can get new plugs, plain old champion copper plus please, clean all the secondary surfaces free of any oil- even grease from hands- and see where you're at
Old 04 Aug 2012, 11:45 am
Thanks,
That's what I installed the copper, does the car have a vacuum canister or is everything right off the engine? I sprayed it with carb cleaner and starting fluid , could not find anything.
Thanks
Old 04 Aug 2012, 01:11 pm
Sorry, although you said it, I didn't comprehend.
in '01 FSM (you may be able to get one from Chromenut or google 'pt cruiser FSM download' [pdf town]) shows a vacuum storage canister in vicinity of horns on cruise control equipped models
Old 04 Aug 2012, 04:00 pm
wat u takkin bout Mainard.....
An old gauge out of my 65 Olds 442...its not really connected.
2008 PT Cruiser shaking & sputter help! Lilsispatrick Tech & Performance Forum 7 05 Jun 2012 12:25 pm
shudder and sputter when in 4th gear pppt03turbo General Turbo Discussions 2 25 May 2012 08:35 pm
04GT Cough, Sputter, Die!! JPMS GT General Turbo Discussions 1 11 Jun 2004 01:04 pm
EGT readings RobGT Turbo Performance 9 11 Jun 2003 05:29 pm
...high rpm sputter... earringboy Turbo Performance 4 25 May 2003 08:48 pm
