PT Reliability
Like Tree11Likes
  • 8 Post By Badglas
  • 1 Post By KyCruiser502
  • 1 Post By Busted_PT
  • 1 Post By UptownSport
Old 06 Aug 2012, 12:04 am
Badglas's Avatar
Default PT Reliability
Evening all. Just a note about reliability. I've seen many posts that make this seem to be an unreliable vehicle, and there some of the opposite view. When I bought this it was project. I've turned a wrench my entire life, but knew little about Chrysler, let alone a PT Cruiser.
This PT has had some really rough years (see my other posts), so I decided to tear it down so that I knew it would be reliable. I wanted to be proactive, rather than reactive after reading many of the posts here on the forum. You can see what I'm up to in the projects forum.
Okay, to the point. This PT has 109000 miles on it. The inside of the engine is spotless. Everything was original, from the spark plugs to the accessory drive belts. So this PT has performed flawlessly even when neglected, and required no service other than oil changes for 109000 miles. I'm impressed! It speaks highly for the quality and reliability of the PT, and explains why shops are going broke.
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 06 Aug 2012, 09:53 am
sonocativo's Avatar
Default Re: PT Reliability
Should the PT owners that have constant issues cahge everything over from a neon? I have owned neons and never had issues like these things have, just strip everything down fome the clusters to the ECM and start over...lol
Old 06 Aug 2012, 10:41 am
I thought in one of your earlier posts, you were going to sell this car that is giving you so much trouble. Maybe get another neon. lol
As you can see, adding the lol at the end of a post as you did, doesn't really change the meaning of a post.
Jerry
Old 06 Aug 2012, 11:02 am
I'm on my second 2001 Cruiser. 230,000 plus miles on the first. Only replaced the computer after a bare spot in a cable shorted it out. #2 has 229,000 plus miles and only replaced the timing belt, plugs, wires and coil. I would say that's pretty reliable. Your mileage may vary.
Busted_PT likes this.
Old 06 Aug 2012, 11:45 am
I bought mine new 2.5 years ago and have about 27k miles on it now. The reliability I would call questionable.
I've had about 2 dozen individual problems with it, from failed seat switches all the way to air bags that have come loose. My most severe problems have been my airbag coming loose, one of my ABS sensors failing, and the power seat switch failing, forcing the seat all the way forward and rendering the car undriveable (as the seat was too close to the wheel for me to even fit in).
I do have to admit, though, that even though I've had more problems than I can shake a stick at, the car has never left me stranded.
-Chris
Old 06 Aug 2012, 11:56 am
sonocativo's Avatar
Only selling to get custody of my son and a divorce, no luck yet so I may end up keeping it. I need to get some money sent off to get that spare tire carrier as well from a member here.
Old 06 Aug 2012, 08:27 pm
I find that on most used cars it's the repairs or the half a$$ execution there of, that causes the chronic issues that plague those who are reliant on others to take care of there cars. Those here that have done very little or done their own repairs seem to have fared way better than the ones had repairs done by others. Low miles seem not to be necessarily favorable.
When I encounter this and correct these things, I find I have a pretty good car afterwards.
UptownSport likes this.
Old 06 Aug 2012, 10:48 pm
UptownSport's Avatar
Garages just slam stuff- then blame you.
The old 2.4/2.0 was a good engine, they changed some stuff with PT, then again with later models;
It's generally not the engine that gives trouble- everything else. (BIG DISCLAIMER ON THE 2.7)
You'll also note, the simpler the car, the more reliable.
If it doesn't have electric seats; switch can't fail
No AC, can't fail
etc.
I'm sure you're all imagining Uptown rolling around in his 1922 jalopy without the electric start or heater option muttering something about 'that's the way I like it ...'
Vlefaive likes this.
Old 07 Aug 2012, 06:11 am
No AC, can't fail
etc.
I'm sure you're all imagining Uptown rolling around in his 1922 jalopy without the electric start or heater option muttering something about 'that's the way I like it uh hu uh hu!...'
Yep, KC and the sunshine band and a old jalopy. I got ya.
PT Reliability Merlin1 General PT Cruiser Discussions 16 17 May 2012 01:45 pm
PT Cruiser Reliability Merlin1 General PT Cruiser Discussions 26 28 Dec 2011 10:34 am
Reliability question GolowDrew General PT Cruiser Discussions 11 20 Jan 2008 11:00 pm
Reliability Oldtimer Tech & Performance Forum 1 23 Oct 2007 07:26 am
Reliability Yellow PT Tech & Performance Forum 19 27 Feb 2007 01:58 pm
