Front Bumper Removal
Old 07 Aug 2012, 09:14 am
Default Front Bumper Removal
Hello, I need to remove the front bumper (Plastic) on my 05 to repair some cracks. Don’t know if it can be repaired or just replaced.
Looking for a step by step instructions to do this but could not find from forum search. Can someone point me in the right direction? Thanks.
Also what kind of glue is recommended to fix a crack?
Old 07 Aug 2012, 10:13 am
Default Re: Front Bumper Removal
Hello, I need to remove the front bumper (Plastic) on my 05 to repair some cracks. Donít know if it can be repaired or just replaced.
Do you mean like the ones at the bottom of this thread (page) listed under "similar threads"? They would have come up when you did your "search"
Jerry
Old 07 Aug 2012, 11:00 am
Ive used "Bondo" plastic bumper repair as well as Plastic epoxy, not the quick stuff, but the epoxy that take a little bit to set.
2 weeks after i got my PT, the GF lightly rear ended someone and broke the license plate off and the screws gouged the bumper on the top. After i smoothed the rough edges of the gouges and fill them in with the plastic bondo filler, let cure, sanded smooth, painted and clear coated. I also had a 5-6in crack on the drivers side bottom corner, which i used the regular epoxy and heavy duty wire screen inbedded in the epoxy on the back side and filled in the front with the Bondo filler, again sanded and paint/clearcoated. Here is a couple of pic of the top of the bumper. I couldnt find the picture i had right after i fixed the top, but the second picture is a recent one and everything is holding up wonderful. The body shop wanted $350+ to repair and paint the bumper cover, i fix it for under 20 bucks. I do still plan on buying a new bumper cover just not in a hurry to do so now, since it still looks pretty good.
Gouging is from the bracket screws, i used rubbing compound to remove the bumber transfer (dark smudges) from the bumper.
Still looking good...this was during my headlight resto a few weeks or so ago.
Old 07 Aug 2012, 11:33 am
Great idea to use wire screen with the epoxy. I have some 45 minute cure time epoxy.
Did you just use a rattle can paint to finish? If so what kind?
Thank you, found the bumper removal at the bottom of the page.
Newbie here, duh ....
Old 07 Aug 2012, 12:21 pm
Honestly the damages werent big enough to use spray, i just used Mopar touch up paint, i would put a coat on, let it dry and wet sand, i think in all i put about 3-4 coats, and blended it in the best i could.
Old 07 Aug 2012, 01:42 pm
Yep, going to try that also and see how it comes out...Thanks
Old 07 Aug 2012, 07:07 pm
mdfrodolives's Avatar
For those who would like a video on removing the front bumper, then Google "Replacing headlights in a PT Cruiser". Go down a few posts until you find a YouTube video on the subject. Click the link and watch the guy remove his bumber to get to his headlights.
Tim
How to on front bumper removal for 06 PT ?!?! IronmanPT General PT Cruiser Discussions 5 04 Aug 2011 09:55 pm
Rear bumper removal Rocketman General PT Cruiser Discussions 6 19 Oct 2004 10:57 am
Rear Bumper Removal SilverPTLTD Exterior Accessories Forum 2 02 Feb 2004 08:19 pm
YES!! Rear bumper and front bumper FINALLY on!! RobGT Exterior & Interior Styling 12 28 Apr 2003 04:23 pm
YES!! rear bumper and front bumper finally on!!! ptcruzin42 Exterior Accessories Forum 0 01 Jan 1970 12:00 am
