Whining noise?
Old 09 Aug 2012, 12:31 pm
Default Whining noise?
I've got a 2002 with 92k miles.I pulled in the driveway last night from work & noticed a whining noise similar to an alternator bearing.Couldn't find anything obvious.Went out this morning no noise.Drove to my local mechanic & it was back after about 5-7 miles.I have to take it back in the morning so he can put it up on the lift for a better look.I'm not driving it to work,just let it set(duh).Sounds like torque converter issues to me,what do you guys think?
Old 09 Aug 2012, 12:45 pm
Default Re: Whining noise?
Noise is a hard thing to diagnose over the internet. Could be a lot of different things. If you said "noise from a particular part" then maybe we could take a good guess, but "noise" and can't be distinguished between engine and chassis, too broad of a statement.
Old 14 Aug 2012, 11:21 am
Here's an update:
I took it to my local mechanic,he changed filter & fluid in the transmission which helped a lot.Shifts good,no whining noises,seems to be fine.Hopefully that's all it needed.I'll drive it to work tonight,70+ miles,that should give it time to warm up.I'd say that will be a pretty good test to see how it will be.I'll keep you guys posted.
Old 22 Aug 2012, 10:14 am
Originally Posted by gizzy View Post
Here's an update:
Didn't last,put about 100 miles on it & it let go.
Whining / grinding noise. PtOnAir Tech & Performance Forum 13 09 Dec 2012 04:44 pm
whining noise estrada Tech & Performance Forum 3 02 Jan 2011 08:56 pm
Whining noise when turning PTBoozer General PT Cruiser Discussions 4 01 Mar 2010 12:13 pm
whining noise coming from car? feefeethaflee Tech & Performance Forum 14 14 Feb 2010 10:50 pm
whining noise when acceleration??? ruzz1 Tech & Performance Forum 9 09 Nov 2007 07:46 pm
