Front fender rust
Like Tree2Likes
  • 2 Post By VNT
Old 11 Aug 2012, 07:23 pm
Default Front fender rust
I was under my 2001 PT Cruiser today and painted the new crossmember and control arms. I looked under to see if there was more rust and found the underside to be real clean then I noticed under the right front fender behind the wheel there was crumbling muddy rust. I cut out the bad areas and was able to take out the two screws that held what was left of the fender. I plan to wash out under the fender, blow it dry and fabricate a new piece for the bottom of the fender. I can't understand where the muddy rust came from, I suspect a drain became clogged. My car has AC and a sunroof. Anyone else have this problem? Is this where the sunroof drains?
Old 11 Aug 2012, 07:33 pm
VNT's Avatar
VNT VNT is offline
Default Re: Front fender rust
Are you talking about the area in front of the door where it raps under?
You should remove the inner fender liner and clean all the muck out, it builds up at the base of the wheel arch where the mud flaps go.
I Paint all my cars underneath to prevent that condition and every few years yank out the liners and clean the stuff out.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 11 Aug 2012, 07:45 pm
VNT is allover this one. Very common to get leaves and dirt in this area. Holds moisture and if left alone will rust this area.
Old 11 Aug 2012, 09:16 pm
UptownSport's Avatar
Ditto!
In the Great White North, the leaves will cause water to run between fender/door then freeze.
Crunch.
You can flush area when you're at car wash; spray hose into plenum by windshield wipers, that area is where it drains.
Obviously, removing that piece of felt or whatever when you have the door open's better, but not easier
Old 12 Aug 2012, 06:17 am
Yes VNT, that's the area I'm talking about Took out a cup of wet mush I will remove the liner as you suggested and flush out. Thanks, Barry
drivers side front fender for 03 randymandy Classifieds: For Sale/Trade 8 31 Jan 2017 10:37 am
Rust alert!!!! (the official rust thread) Ironman The Detail Shop 22 28 Apr 2012 10:25 pm
Need R front fender and door J3t Classifieds: Want To Buy 1 26 Oct 2011 12:04 am
front fender needed mills22 Classifieds: Want To Buy 0 26 Nov 2010 05:58 pm
Bottom of front fender damaged on '06 GT Vert. wayneman The Detail Shop 10 14 Jul 2010 08:41 pm
