rattleing rear end??
Old 13 Aug 2012, 09:02 am
mdskinner731's Avatar
Default rattleing rear end??
i took the rear seats outrta my cruiser to clean my interior, b4 i left to go camping! i kept the rear seats out to see how much of a difference in fuel mileage i could save. (honestly not enough to say so.) with the rear seats out i can hear a serious rattling in my rearend, (no im not a rattlesnake) every time i hit a bump the noise is horrible. clattering; metal on metal; clashing almost.
has anyone ever expirenced this before? if so what coul it be?
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
Old 13 Aug 2012, 09:18 am
sonocativo's Avatar
Default Re: rattleing rear end??
Mine does it because I have no spare tire carrier and the rod just dangles in the hole in back.
Old 13 Aug 2012, 09:20 am
spare tire is still there. :-/
Old 13 Aug 2012, 09:22 am
crazyptguy's Avatar
could be the same as mine and be the watts link
03 Pt Woody Classic 116k miles Rebuild project.
Old 13 Aug 2012, 09:38 am
really?? again... lol that aint fun to change
Old 13 Aug 2012, 10:09 am
grab your spare tire and see if it's in there loose. did you ever fix your weird wear pattern on the tires? maybe it's related. also check the shocks are tight and the top rubber bushing is in ok condition. i just fixed a GTP that sounded awful because the rubber bushings were shot
Old 13 Aug 2012, 10:59 am
no rear tire is still chopped. but i did notice that the tires were a little low i pumpped them back up and i havn't noticed any further chop. but ill possible put it on the lift this weekend and check the shock/s
Old 16 Aug 2012, 11:42 am
I was just given a 2001 PT Cruiser with only 86,000 miles ,,,
I had to replace the PCM and new rims to get it running and road worthy.
thinking it was ready to go ,,,, i drove it for the first time -
Shocked by the extremely loud bang/clunk/rattle going on underneath ??!!
It was the watts link ,,,,,,,,, The center pivot has 1/4+ slop.
It is attached to the top of the "rear axle beam" ,,, facing forward.
I thought something was going to break. Not sure if it is normal for it to be
worn out this soon ?
Old 04 Sep 2012, 11:22 am
Yup my "side to side clunk" was the Watts link on our 01 with 70 K miles. About a $90 dealer part , luckily they had it. Start soaking the area with Pen oil if everything will break loose and i did it under a jacked and supported car (2 hrs not so easy) D~
Old 04 Sep 2012, 12:21 pm
if it aint the tire mount for the spare.
Its the wattslink. No question.
Sorry friend.
Napa carries the link for $69 including tax.
Need a picklefork to remove the boots. may have to chase some threads. about a 2 hour job.
WTB: Rear Say Bar / Rear Springs for Base Model Maxxam Classifieds: Want To Buy 2 11 Mar 2008 08:22 pm
245/40/18 on Rear Meeks Tech & Performance Forum 3 24 Feb 2003 08:36 pm
