Coolant leak
Old 13 Aug 2012, 04:45 pm
Default Coolant leak
Help!....My 2002 PT with 76,000 mi. started over heating and I flushed the cooling system with Pennzoil heavy duty radiator flush and it worked fantastically, (there was lots of rust in the system). I replaced the thermostat and seal and also the radiator cap....but I still have a leak some where. I am getting coolant "spraying" on the front pass side of the head (it builds up in the area where the head bolt is), It's not a crack in the filler neck that I can see, I know the water pump is working well because the heat works and is very hot no smell of coolant in the car so it's not a heater core, no leaks on the ground, no leaks in the hoses or any where else that I can see. How easy is it to warp the heads and how easy do the head gaskets start leaking? It seems to run out of water, over heat and there are no leaks to show for it except the water on the head. Please help!
Old 13 Aug 2012, 05:14 pm
Default Re: Coolant leak
are you saying there's nothing but water in the radiator?
Old 13 Aug 2012, 06:13 pm
quite possibly a head gasket. Are you seeing any water in your oil??
Old 13 Aug 2012, 08:08 pm
mdfrodolives's Avatar
Fill her up with coolant again and start her up. Look down the thermostat housing cover (under the rad cap) and see if the bleeder screw is loose or busted. Also, did you torque the thermostat housing bolts to 110 INCH pounds? Did you make sure the nub in the new thermostat gasket was put in the nook of the thermostat housing cover?
Tim
Old 13 Aug 2012, 08:14 pm
Badglas's Avatar
If you are finding coolant on top of the cam cover in the bolt recess (the head bolts are not exposed), check the hose between the reserve tank and the filler neck for a hole. Just a guess, but that was the clue that led me to find the hole in the reserve tank hose on mine. It overheats because it can push coolant into the bottle, with a small amount landing on the cam cover, but cannot create a vacuum to draw coolant back into the system.
Or, Chrome might be right!
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Coolant Leak TimWeaver Tech & Performance Forum 6 13 Jul 2012 08:55 pm
PLz help= Coolant leak PtC06 Tech & Performance Forum 2 04 Dec 2010 02:01 am
Coolant Leak dfales General PT Cruiser Discussions 7 18 Dec 2009 06:30 pm
Coolant Leak rcalzadilla Tech & Performance Forum 29 25 Oct 2009 01:29 pm
coolant leak RaceWilson Tech & Performance Forum 7 14 Sep 2008 09:49 am
