'04 codes read 0522,0335. Stalling at stopsigns and lights?
Old 14 Aug 2012, 01:49 pm
Default '04 codes read 0522,0335. Stalling at stopsigns and lights?
My car has been stalling or sputtering out at stop signs and lights. Sometimes catching when accelerating. When the check engine light was on the codes read 0522 & 0335. Are these symptoms of the codes? Thank you...any help is appreciated.
Old 14 Aug 2012, 01:57 pm
Default Re: '04 codes read 0522,0335. Stalling at stopsigns and lights?
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
I would think that the CPS would certainly cause rough running conditions
Old 14 Aug 2012, 03:35 pm
On an 04, the CPS/CKP is behind the starter.
Old 14 Aug 2012, 03:39 pm
As usual, all above are correct. Change the CPS first, and make sure you buy an OEM one, not some cheapo Chinese made after-market sensor, it will not last and for some reason the PT's don't work well on after-market sensors.
Ignore the second fault until you get the CPS swapped. Once that's complete, pull the negative lead off your battery for at least 5 minutes. Suggest stepping on the brake pedal a few times to quicken the bleed-off of any redundant charge on the circuits.
After that, your codes will be cleared until they occur again. After swapping the CPS, drive for a couple of days then do the 'key dance' and see if you are still exhibiting any other error codes.
Old 14 Aug 2012, 04:24 pm
Wow! Y'all are quick! Well, I changed the cam shaft sensor about 3 months ago and the code I have for that is 0344. I have the engine oil pressure sensor switch circuit low voltage for 0522. I hope I'm not on a too far off path
Old 14 Aug 2012, 05:11 pm
Yep, your right. The old Oil Pressure sensor. As Chromenut stated, change the Chankshaft sensor first, clear all the codes and if the p0522 comes back, pick up a sensor from the dealer and go at it. Some took the battery and air filter off to get easy access to the pressure sensor.
Old 09 Nov 2012, 08:54 am
Moutray's Avatar
Hello all, new guy here. Having the same sluggish, stall, won't start, codes p0335/p0522 problems. Took it to a local shop and they raped me. Brought it home and the problems started again. They changed crnk/cam sensor, oil pressure sensor. I suspect cheap parts to be the culprit. How important is it that the part be Mopar, not Autozone? I'll let you know the outcome.
Old 09 Nov 2012, 11:56 am
The Crank and Cam sensors definitely need to be OEM but not sure about the OIL Pressure sensor.
Old 10 Nov 2012, 03:00 pm
Moutray's Avatar
It seems impossible to get to! under the starter? How do you get to that?!
Old 10 Nov 2012, 03:04 pm
Something to read:
Crankshaft sensor replacement on an 06
2003 PT Cruiser GT stalling at 2500rpm's and multiple error codes Presidente3 Tech & Performance Forum 1 10 May 2012 12:58 pm
No start/stalling, plus 2 trans codes PMO623 Tech & Performance Forum 7 11 Mar 2011 01:01 pm
0522, 0340, 0335 bjagd02 General PT Cruiser Discussions 3 26 Feb 2011 05:35 pm
Error Codes 0522 and 0442 logicalfrank Tech & Performance Forum 3 01 Apr 2010 11:57 am
Help! Hard starting and hesitation - Codes 0171 & 0522 THS_Cruiser03 Tech & Performance Forum 10 08 Aug 2008 02:36 pm
