Pyt just died on highway with key on running at 70mph just died no warning now won't start. wasn't over heating while running but now guage shows hot. any help please.
Id go with timing belt, if no oil lights then its prob not a siezed engine... Id also bet on a camshaft position sensor maybe too. Did you try the key dance?
![]() ![]() If You Have Not Already, Add Yourself To The PT Cruiser Members Map! To Learn More About My PT Cruiser And Its Mods Visit My PT's Blog At www.PickledPt.blogspot.com |
100,000 miles. key dance? 2002 pt cruiser.not turbo
holy crapoly - I'd say the belt snapped. Did you try the key dance to see if you have any trouble codes?
Here's the simple steps to the key dance:
As I said in the PM you sent me, probably the timing belt if you are anywhere near 100,000 miles, and you are.
The key dance is a way of getting any faults that the computer sees from any of the sensors. Chromenut gave you the fast and dirty. Here's the whole procedure and remember to do the on/off sequence in less than 5 seconds. Sounds hard but it's not. How to retrieve fault codes. If it is the timing belt, you should see a fault like P0340 which means the Camshaft sensor isn't seeing a signal which happens when the camshaft isn't turning anymore.
Rules of the forum have been updated as of *07/07/2019* Please read them over. - All decisions by the Moderator are semi-permanent, can and may be changed at his discretion but definitely will be the final word. Any action performed by the Administrator or Moderators are not to be discussed on the forum. |
any idea what the cost to replace the timing belt should be.
Mine was $1200 but then he found a leak in the seal around the Crankshaft. Only a bit more in labor involved since he was already in the area.
thanks....holy crap!!!
Thread Tools | |
Display Modes | |
Directionals and Emergency flashers won't work | kupothechocobo | General PT Cruiser Discussions | 10 | 16 Apr 2009 05:54 pm |
PROPER USE OF THE EMERGENCY BRKE | GALVANIZEDYANKEE | Tech & Performance Forum | 0 | 23 Oct 2008 01:41 pm |
PROPPER USE OF THE EMERGENCY BRAKE | GALVANIZEDYANKEE | General PT Cruiser Discussions | 0 | 23 Oct 2008 01:36 pm |
Emergency Brake | proxeyed | Tech & Performance Forum | 8 | 21 Feb 2005 12:56 pm |
