? About buying a gt cruiser
Old 16 Aug 2012, 12:43 pm
Question ? About buying a gt cruiser
I saw and ad for a 2003 gt cruiser for 2600$cdn with 107000kms (~66000 miles). The price seems good ( the guy is not advertising it as a gt, prob doesn't think it matters) for the mileage... just wonder if it's the real mileage.
Could anyone tell me what I should be looking for? If its only been on reg gas is that a deal breaker? This would be my very first car so I want to be sure it doesn't become a nightmare. Also it's an automatic gt if that matters.
Thanks
Ps I'm new to car mechanics. Just started to learn about alternators, timing belts etc
Old 16 Aug 2012, 01:48 pm
Cruiszr's Avatar
Default Re: ? About buying a gt cruiser
Not a mechanic but don't think it would matter about regular gas as long as it not a "High Output Turbo". It is normally marked on the rear under the Turbo 2.4 logo.
If I'm wrong I sure someone will correct me
2008 Touring -9050 miles (Cash for Clunkers trade-in)
2008 Miata MX5 Vert. 30000 Mi
2000 Astro Con. Van. 58000 Mi (One owner)
2005 HD Sporster 1200, 8000 Mi
Old 16 Aug 2012, 04:18 pm
Oh, I was under the impression all GTs are HOs...
That would explain why this GT doesn't have the HO label. I thought
maybe it had fallen off or he took it off
Well that's good to know ill save money on gas. If its not HO does that mean less HP?
Thanks
Old 16 Aug 2012, 06:01 pm
VNT's Avatar
VNT VNT is offline
In 03 they didnt have an HO badge, in 04 they came out with a 180HP version so they added High Output badging to the GT
Test drive, ask for maintenance log book and records. If original owner ask if he has the window sticker and any other documentation.
Do key dance and check for codes. Look under oil cap on valve cover, if all sludged up keep looking.
Ask rather casually where he had oil changes done, and what kind of oil.
Lastly have a mechanic check it out, wont get burned that way.
Things to look for are bad Lower control arm bushings, make sure all the electrical works(door switches, windows, locks, radio, sunroof. etc), turn on AC and make sure it is cold and step out and make sure fan is running.
Take for spin, listen for noises, known for bad front wheel bearings, look in overflow tank make sure there is orange coolant, if green someone is using wrong coolant.
Oh the 03 HP was 215.
Does car have leather and heated seats?
If not mechanically inclined bring it to mechanic before you buy it
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 16 Aug 2012, 06:06 pm
^^^^ this and also any PT GT should be used on premium gas
Old 16 Aug 2012, 06:09 pm
2step's Avatar
The GT (aka: high output) can run on regular, 86. The sticker on the fuel door and the manual says "premium recomended". (A stage 1 PCM is labeled "premium REQUIRED".) Anyway, the GT PCM will adapt to the regular grade fuel by dailing back the spark advance and boost for less power and less stress on the engine. Actually not a bad thing at all. I had a 250 mile per day job back when I owned my first GT and all I used was regular. It ran like a Swiss watch and even won a few stoplight challenges. The 50 trim, big turbo I own now is a different story altogether.
Personally, I would look for signs that the little tubes and hoses that route from the turbo to the solenoids and wastegate actuator have been hacked or replaced by non-stock looking hoses. That's the usual tell-tale that the boost has been raised higher than the factory settings.
Old 16 Aug 2012, 07:11 pm
VNT's Avatar
VNT VNT is offline
look for iron worms in rocker area under the doors, especially in front of the rear wheel arches whee they rap underneath.
Some threads on here about rust with pictures.
VNT
Thinking of buying used '08 Cruiser beej123 General PT Cruiser Discussions 0 16 May 2011 09:50 am
Debating buying a Pt Cruiser Daytondave General PT Cruiser Discussions 35 16 Mar 2011 08:48 pm
Buying a PT Cruiser: anything to worry about? Jopperm2 General PT Cruiser Discussions 5 09 Jul 2010 10:11 pm
Buying a pt cruiser for the first time AriaDraconfly General PT Cruiser Discussions 18 04 Jun 2010 04:54 pm
buying pt cruiser,help please jezzamagic General PT Cruiser Discussions 8 26 Jan 2009 05:52 pm
