Temperature gauge question 07 PT
Old 16 Aug 2012, 04:35 pm
Default Temperature gauge question 07 PT
Hello everyone,
A month ago I had a over heating issue that I finally have fixed.
Now, When engine is cool and I start to drive as my temperature gauge reaches for normal it doesn't STOP it quickly goes all the way up to RED making a ding sound (as if it was re-setting or something) then drops back to normal.
I ask this, because it keeps doing it every time I start driving at cool engine temps.
Has anyone had this issue?
**note: NO check engine light
What I have replaced for the over heating issue:
-Radiator + Fan + harness+ relays from dealer.
-Cap and thermostat
-ECT sensor
-timing belt-water pump
Old 16 Aug 2012, 04:51 pm
UptownSport's Avatar
Default Re: Temperature gauge question 07 PT
Geeez
I'd guess it IS overheating.
ECT = CTS? (Coolant temp sensor)?
Overheats will destroy the vernatherm in thermostat, or there could still be a leak and causing engine to be full of air-
Do this, when it goes to the ding ding, open hood and toss some water (or just spit) directly on head or block- see if it sizzles.
You could bleed it, plenty of posts on how- to's, basically you open the brake bleeder looking thing with 3/8 socket (10mm six point will work in a pinch) until bubbles stop coming out
Hopefully I'm wrong, but if it is over heating that's not good for it.
Old 16 Aug 2012, 05:17 pm
Yes, CTS (Coolant temp sensor)
Its not over heating the, gauge just goes up makes a ding and drops back down.
I thought I got all the bubbles out.
Originally Posted by UptownSport View Post
Geeez
Old 18 Aug 2012, 10:04 pm
I have only found that the connector is bed but, have no idea where to buy a Engine Cooling Temperature Sensor connector.
When I disconnect the connector. The temp gauge drops all the way down.
The ETC was bought from autozone
Temperature Gauge Not Working! PhuckinTuffCruiser Tech & Performance Forum 5 14 Oct 2011 03:46 pm
Gauge Pod install question bhunt41 Interior Accessories Forum 9 31 Dec 2010 09:39 pm
A/F Gauge question KLCruiser Turbo Performance 2 19 Jul 2008 12:02 am
Gauge light install question PT-Dave Turbo Performance 7 20 Sep 2003 08:17 pm
Boost gauge install question NorthernPT Turbo Performance 14 21 Apr 2003 11:35 pm
