Rapid clicking from starter won't start
  • 1 Post By Ray_Dockrey
Old 23 Aug 2012, 09:59 am
Default Rapid clicking from starter won't start
Wife parked PT, came back later won't start. Tested battery...good. Everything works except radio won't turn on and when trying to start only get rapid clicking from starter. Checked relays & fuses, all good. It is a 2001 with 84,000 miles.
Old 23 Aug 2012, 10:19 am
Default Re: Rapid clicking from starter won't start
Either the connections between starter and battery, the ignition switch area, or starter. Try boosting to rule out starter.
How was the battery tested and found to be good?
Old 23 Aug 2012, 10:20 am
Ray_Dockrey's Avatar
How did you test the battery? If you checked it by just testing the voltage that won't work. It may show 12 volts but not be able to put out the amps needed to start the car. i would also check all your connections. If the battery is very old then I would go ahead and replace it. Seems like these cars are very sensitive to low battery output.
Busted beat me to it so sorry for the repeat info lol
Busted_PT likes this.
Old 23 Aug 2012, 06:53 pm
I figured at first it was the battery. Went to auto zone & before I paid for it, I asked them to check it. Thier meter read that it was fine but needed a charge. I took the old back & checked the cells with hydrometer, they all read between fair to good. The meter on the charger read in the yellow indicating low. Charged it, meter read full charge. Put it back in car, still just got rapid clicking. Hooked up battery charger to jump start, just clicked faster. Had my mechanic tow to shop, he found that the battery was bad and replaced with new. No problems so far.
Thanks for your quick replies.
Old 24 Aug 2012, 12:18 am
PTpreacher's Avatar
Smile Re: Rapid clicking from starter won't start
Could be dirty batt. cable's or a bad solenoid. I have had both problems in the past with other cars...if the batt. is good check those cable ends carefully. clean them with a knife inside the cable and sometimes they will develop a crust on the post themselves. PTpreacher
Old 24 Aug 2012, 05:17 am
You missed his last post. It was a bad battery.
Old 24 Aug 2012, 07:09 pm
PTpreacher's Avatar
Red face Re: Rapid clicking from starter won't start
I'm sorry I did miss that....glad you are doing well now...PTpreacher
2006 GT Won,t start starter not engaging Deac0n Tech & Performance Forum 1 28 Apr 2012 02:53 pm
clicking in wheels veno3122 General PT Cruiser Discussions 0 10 Jun 2011 09:45 am
Clicking on my PT? Help PLZ! CruseadorPT Tech & Performance Forum 2 30 Jul 2009 07:32 am
Hybrid Technologies Completes Lithium Rapid Recharge System for NASA PT Cruiser skylight PT Cruiser News and Rumors 0 01 Aug 2007 01:36 pm
Bye Bye Rapid Craft CREWZIN Vendors & Buyers Forum 1 31 Jul 2003 12:02 am
