gauge question
Old 23 Aug 2012, 10:37 am
crazyptguy's Avatar
Default gauge question
i need to replace my gauge cluster and need to know does the cluster or the computer hold the mileage info. can i buy any new or used cluster and still get the correct mileage? or do i need to find one thats close to my mileage
03 Pt Woody Classic 116k miles Rebuild project.
Old 23 Aug 2012, 11:58 am
Default Re: gauge question
i'm pretty sure the cluster holds the mileage. try to find one that's close.
Old 23 Aug 2012, 01:53 pm
crazyptguy's Avatar
rats! i changed the light bulbs in mine and had the neg terminal off the battery and there was enough residual charge when i plugged it in to pop the circuits in the cluster on the plus side my gas gauge doesnt work and i cant even figure by mileage cause the odometer is all 8s so i am forced to suck it up and drive the wifes cruiser for a while
Old 23 Aug 2012, 03:51 pm
I read on here that the speed o holds the mileage also.
Old 24 Aug 2012, 05:48 am
are we sure it's the cluster that holds the mileage? My reason for asking is, iirc, when you get a new (to your car) PCM flashed, you have to supply the current mileage among other things.
Looking back i always wondered what if you fudged the mileage?
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 24 Aug 2012, 07:19 am
Someone said on here that he bought a replacement unit that had way more miles and it stayed there. Also someone had a stage 1 flashed and didn't have to give mileage. So thats what I based my answer from.
Old 24 Aug 2012, 10:42 am
2step's Avatar
There must be some kind of reverse fail safe where the gauge cluster and the PCM have to agree or be close enough or else it would be too easy for a dealer or mechanic to "roll back" the mileage.
Old 24 Aug 2012, 11:11 am
crazyptguy's Avatar
thats the reason i was wondering if the gauges hold the mileage a dealer or individal could easily roll back just by changing the gauges we got the mileage and the gauges working again by cleaning the contacts on the harness but no lights except emergency lights so im looking at a set of glowing gauges. been searching for installation videos to see how hard they are to install
Old 24 Aug 2012, 12:17 pm
Too much jail time and paper trail for a dealer to bother with rolling one back.
Old 24 Aug 2012, 02:37 pm
The only way to retrieve mileage if the odometer is out is to use a DRB and scan the engine controller. Chrysler warns, though, that the engine controller is not intended to provide "exact" mileage.
Therefore, the exact mileage is only stored in the cluster.
-Chris
Temperature gauge question 07 PT cruiser07 General PT Cruiser Discussions 3 18 Aug 2012 10:04 pm
Gauge Pod install question bhunt41 Interior Accessories Forum 9 31 Dec 2010 09:39 pm
A/F Gauge question KLCruiser Turbo Performance 2 19 Jul 2008 12:02 am
Gauge light install question PT-Dave Turbo Performance 7 20 Sep 2003 08:17 pm
Boost gauge install question NorthernPT Turbo Performance 14 21 Apr 2003 11:35 pm
