Timing belt trouble! please help asap
  • 1 Post By msmoorenburg
Old 11 Sep 2012, 01:54 pm
Default Timing belt trouble! please help asap
I'm doing a timing belt, water pump, tensioner, idler swap. Trouble is, i never marked anything before taking it apart. also i took cam gears off amd rotated cams. so basically im starting from scratch. the valve cover is off so i can see what cylinder is doing what. i know tdc but i dont want to be 180 degrees out. please help, i need to get this done. thanks
Old 11 Sep 2012, 02:26 pm
Default Re: Timing belt trouble! please help asap
If your timing marks line up your in time. Make sure all the valves on #1 are closed. There is a how to at the top of tech section if you need it. Start it before you put it all back in case your out a tooth.
Old 11 Sep 2012, 02:37 pm
thanks so as long as the cams are i time, i should be ok? also could my crank be out 180 degrees or no. and if so, is there anyway to tell.
Old 11 Sep 2012, 04:12 pm
Crank one mark only. Cams have two marks. Must use 2.4 side of sprocket and the up side marks!
Old 12 Sep 2012, 01:05 am
good to go. thanks guys. hopefully goes well
Old 12 Sep 2012, 08:33 am
Check tech & performance page for timing belt tips for link on how to change belt! It will be worth your time!
Old 12 Sep 2012, 09:11 am
yeah what he said. start AND rev it. if you're off it can still idle but will not rev up.
really, make sure you do this.
Old 12 Sep 2012, 09:25 am
here ya go
Busted_PT likes this.
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
HELP ASAP! TIMING BELT ISSUE... firebirdcabrio Tech & Performance Forum 16 28 Oct 2011 02:14 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
