fog lights do not work?
Old 20 Sep 2012, 07:37 am
mdskinner731's Avatar
Default fog lights do not work?
driving home the other day i had run over a fox right there after i lost my fog lights ( as in they do not work ) the little indicator light on my dash dont even come on?? i've searched high and low across this site and google with out any luck. now its time to turn to the "pros"
upon visual inspection there is no broken lights/bulbs. no wires outta place and everything seems to be in workable condition but they just will not turn on??
i am going to "assume" that it aint the MFS because the lights worked, i hit the fox, and now they dont work
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
Old 20 Sep 2012, 08:00 am
Default Re: fog lights do not work?
Is the mother of all screw ups!
Did you meter out the bulbs. Filament could be broken, sometimes hard to see.
Old 20 Sep 2012, 08:02 am
You did check the #8 fuse, right?
Old 20 Sep 2012, 11:02 am
Hmm, #8 fuse huh? My fogs don't work either and I did not hit a Fox! Although ours is used so maybe it did!
I just "assumed" it was the bulb, I'll start to check it out this weekend.
Old 20 Sep 2012, 11:08 am
The #8 fuse is in the interior fuse box. If either of you have the 2006+ cruisers, there's no interior fuse box so forget that advice.
Old 20 Sep 2012, 11:24 am
I'm a 2001 Limited, gonna go check the fuse!
Old 20 Sep 2012, 11:41 am
If it's missing you need to repair the mfs or buy one.
Old 20 Sep 2012, 11:50 am
ill look to see if that fuse is blow and also, if one bulb was bad sholudnt only that 1 light be out??
Old 20 Sep 2012, 11:57 am
Yes, you would think so like the headlights, you can only have one out and the other would work.
The "fox" could have somehow hit the wiring harness and screwed up the wires, like grounding the hot wire. That would blow the fuse. Did you check yours?
Old 20 Sep 2012, 12:25 pm
It's not there...no fuse, what's the value and what's a mfs??
my door locks,head lights and tail lights don't work. bones02 Tech & Performance Forum 38 06 Apr 2016 10:30 am
No lights and door locks don't work Mopower71 General PT Cruiser Discussions 0 19 Dec 2011 03:07 pm
Tail lights wont work tjc General PT Cruiser Discussions 5 12 Oct 2011 02:46 pm
Some brake lights work UTIStudent General PT Cruiser Discussions 10 14 Jun 2011 10:17 pm
2001 Limited fog lights don't work redrider02 General PT Cruiser Discussions 11 03 Aug 2009 07:52 pm
