Help!!! smoke and belt problem
Old 28 Sep 2012, 02:50 pm
Default Help!!! smoke and belt problem
Driving 03 pt home and all the sudden car startes to idel ruff smoke from belt burning and a loud noise... any help would be great...
Old 28 Sep 2012, 03:24 pm
Ray_Dockrey's Avatar
Default Re: Help!!! smoke and belt problem
Was the AC on and did you turn it off if it was?
Old 28 Sep 2012, 03:27 pm
if i were you i'd slip off the serpentine belt and see if the pulleys on the AC compressor and power steering both spin freely.
Old 28 Sep 2012, 03:42 pm
You definitely have your problems. Your first couple of posts said you overheated and your father-in-law tested the wrong part of the fan harness. You never said if that issue was ever corrected. Now the smoke, smell and loud noise. I'm with the two guys above. Sounds like something (A/C, PS) might have locked up causing those symptoms. We can guess all night but somebody has to get their hands dirty and find out which belt was burning and what caused the noise.
Old 28 Sep 2012, 04:12 pm
OK guys fan isnt working.. last time it over heated I changed the low speen relay and the fan started working agine...this time When I changed it it didnt do anything going to test the fan when I get home and see if it is working or not...
Old 28 Sep 2012, 06:33 pm
Ok guys just tested the fan and it works.... need some help I dont know where go to from here.. Fan will not come on when car is started and ac is on...
Timing belt instilation problem. Futurechrysler Tech & Performance Forum 4 15 Nov 2011 10:27 am
A different kind of Timing Belt problem Quicksilver Tech & Performance Forum 7 15 May 2011 03:48 pm
Changed timing belt, New Problem starrlyte99 Tech & Performance Forum 2 27 Apr 2010 07:13 pm
02 2.4L timing belt problem ronwins3 Tech & Performance Forum 18 15 Dec 2008 08:57 pm
Fixed timing belt now another problem EvilWRX Tech & Performance Forum 1 13 Feb 2007 09:35 am
