i just had my head rebuilt, and now I'm putting it back together. Ive never done a timing belt before, and I'm a little worried I might get this all back together and it be wrong. I had a time lining the cam and tdc marks up. the cam marks are lined up now, but they literally look like they are a hair between the two. the crank was on the trailing edge of tdc. i did a compression check on all 4 cylinders. the readings were between 180-185 consistent. i think if it wasnt right then i wouldnt get that high of a reading and it wouldn't be consistent either. let me know what you guys think. please, thanks jon.
There is a step by step how to in the tech section at the top of the page. Also have been a bunch of pictures of the line up procedure. Also you will want to fire it up before you put all the way back to make sure it run right. Real easy to be off a tooth.
hey thanks for the reply. im new to this site, and im not seeing the tech link. can you give me some directions. appreciate the help
Under the Tech & Performance section of the forum we have a tread entitled HOW TO. Here's a direct link. There's about 4 threads inside that one that deal with the timing belt.
HOW TO's
Rules of the forum have been updated as of *07/07/2019* Please read them over. - All decisions by the Moderator are semi-permanent, can and may be changed at his discretion but definitely will be the final word. Any action performed by the Administrator or Moderators are not to be discussed on the forum. |
use a straight edge thru center of cam bolts- otherwise they can look lined up but not be.
you can start it before you put everything back together
Useful Documents Useful How-To's Have an engine code? Sometimes this link is helpful Neon Bobble Strut ^^ Click |
Ok, Im back. Thank you guys for the info and advice. I double checked my marks and my compression,,,,, all were consistent. I now have another problem. I got everything back together and went to start it, but now it wont start. It turns over for a few seconds, but then stops turning completely. It never starts, fires, backfires, or anything. If I turn the key back off and try it again, it does the same thing. I can hear the fuel pump running non stop. I bled the fuel system at the valve on the injectors rod, and it seems to have all the air out, and plenty of pressure. One thing maybe not worth mentioning, is that the tach gauge goes all the way over, and the display shows the cruise come on. I've unhooked the battery, removed the fuse to the fuel pump, but still the same after I hook it back up. No start at all, and the fuel pump continues to hum in the tank. I also sprayed starting fluid in the throttle and held it open while trying to start it, but no luck. Everything ran fine when I parked it to work on it, so I don't think anything new is broke. I feel like it might still have some air in the lines, and the pressure is not building up, thats maybe why the pump continues to run.... but i don't know. Any ideas???
The pump is a 'dumb' system- It works without regard for pressure.
PCM does have a feature that shuts it off if it doesn't get a crank signal* Sounds like you didn't connect something or got the timing off. It will run on a bit of ether, so that should rule out fuel as an issue Didn't disconnect coil and cam sensor by any chance? same plug, same area
yes i did disconnect the cam and coil. I had the head rebuilt. I thought I connetected them back in the right spot. I'll double check that. I sure hope its that, and not the timing. If the belt is off time then Im taking it somewhere else to get it fixed. I am deffinitely not a mechanic, lol. thanks for the info. I will let you know how this turns out.
after you cranked it over a few times, spin the engine over by hand and "recheck" the timing. if you did as i did with swithing the wires you will most likely have to change the PCM.
if it moves and not supposed to... duct tape!!! if it dont move and is supposed to... WD-40!!! ~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~ |
Thread Tools | |
Display Modes | |
PT Cruiser Timing Belt | PTCooler | Tech & Performance Forum | 6 | 15 Aug 2012 03:48 am |
timing marks HELP | petescruiser | Tech & Performance Forum | 5 | 06 Jun 2012 04:14 pm |
02 PT Cruiser Timing belt Help!!! | J5BAIL | Tech & Performance Forum | 2 | 16 Apr 2012 02:31 pm |
Timing marks... | loadedchainsaw | Tech & Performance Forum | 2 | 29 Mar 2011 08:31 am |
timing marks | luko | Tech & Performance Forum | 0 | 18 Sep 2010 06:12 pm |
