How to improve the mileage? thanks
Like Tree14Likes
Old 06 Oct 2012, 06:01 pm
Unhappy How to improve the mileage? thanks
I have a 2006 touring.
The mileage I get now is about 13-14.
I try to seafoam the car last week, but dose not change anything.
and when the car is idle, there is a obvious vibration even in gear N.
Anybody know how to improve it?
Thank you very much.
Old 06 Oct 2012, 06:44 pm
Default Re: How to improve the mileage? thanks
Correct tire pressure has one of the biggest influences in MPG. Check and correct it early in the morning with no sun on the tires. I recommend to read what the tire max. psi is instead of the OEM recommendation unless you are still running exactly what it came from the manufacturer with. Then go -4-6psi below that. Guaranteed to increase the MPG!
You should routinely check your tires wear pattern and tire pressure at least at every other fill up, 500 miles or sooner.
Some vibration is common with this type of engine. You may not be use to it experienced based from previously owned and driven vehicles?
mityqwik likes this.
Old 06 Oct 2012, 06:45 pm
what have you done to the car so far?
is the check engine light on?
have you changed the air filter?
how much air is in your tires?
Old 06 Oct 2012, 06:50 pm
Oh and Welcome to the PT forum.
Old 06 Oct 2012, 07:32 pm
Thank you.
So what psi you suggest? I do not understand "the tire max. psi ". How to know the max psi?
I also plan to change the spark plug and clean the throttle body and IAC recently.
Old 06 Oct 2012, 07:34 pm
Thank you.
I only used seafoam to it.
There is no check engine light on.
I checked the air filter, it is very clean.
I have not check the tire pressure yet.
I remember the recommended value is 35 psi?
Old 06 Oct 2012, 07:58 pm
Look on the side of the tire all that small information you will see what the tire is rated for. In that language you will see Max.Psi . Then follow my suggestion for filling.
Old 06 Oct 2012, 08:13 pm
I just checked my rear tire, and found that the edge tread wear much more than the center tread.
So I think the pressure is a little bit lower than the standard.
The desired situation should be the the tread wear evenly from the edge to the center, is that right?
Old 06 Oct 2012, 09:07 pm
Yes.
Now you should check the information I suggested.
Old 07 Oct 2012, 07:57 am
Ray_Dockrey's Avatar
How are you checking your mileage? Are you doing the math when you fill it up or are you going by the computer readout on the dash. Using the computer readout is very inaccurate.
Tags
mileage
Resistor module to improve MPG & HP? Bdog Tech & Performance Forum 9 04 May 2008 09:00 pm
improve stereo turbomangt Sound and Security Forum 49 17 Apr 2008 12:14 pm
How to improve sound system Ctown Sound and Security Forum 14 08 Jun 2004 11:50 pm
What's the best mod to improve handling ? Wingdale Dave Turbo Wheels/Suspension/Handling 15 03 Jun 2004 11:03 pm
IMPROVE GAS MILEAGE with this MOD... Gary04GT Tech & Performance Forum 4 28 May 2004 12:21 pm
