Lights pulsing
Old 08 Oct 2012, 07:04 pm
Default Lights pulsing
I have an 03 PT Cruiser Gt, with 160K miles. I changed the battery two days ago and now when I start the car all of the lights, interior and exterior, pulse for about a minute. It also seems to stop because I have come to a full stop. The lights never go off, just pulse. If anyone has any clues I'd appreciate them.
Old 08 Oct 2012, 07:14 pm
Default Re: Lights pulsing
Sounds to me like you've got some connection problems. You need to look at both positive and negative leads between ground and the battery, between the alternator and the battery. You should also crank your stereo loud at night and see if the base thumps along with the lights dimming. This is a sign that you need to do the "Big Three" modification - that is replacing your leads with new ones of larger size. You can find more info on that by going to our PT library, it's the link in my signature block below. There's a document there with instructions on the Big 3.
Old 08 Oct 2012, 07:56 pm
You mentioned the ground wire, and now that you say it the ground wire on my hood is cut. I will replace that, and read the document you mentioned.
Old 09 Dec 2012, 04:57 pm
With the earlier night here, I've found my lights flashing again. They do not change with the bass of the radio though. I've cleaned all ground connections and battery terminals. I do know my multi function switch is bad and I'm wondering if anyone thinks that might be the problem. Any other thoughts are welcomed.
Old 09 Dec 2012, 05:14 pm
I do, I do.
my door locks,head lights and tail lights don't work. bones02 Tech & Performance Forum 38 06 Apr 2016 10:30 am
Head Lights and Tail lights not working. 1morgana General PT Cruiser Discussions 6 15 Nov 2014 12:38 am
Brakes "pulsing" after front pad replace and rotor turning Samson Tech & Performance Forum 8 28 Dec 2011 05:11 pm
Need a poll answered: Should I tint all my lights or buy euro/projector lights? 85_305 Exterior Accessories Forum 2 17 Jun 2009 08:38 pm
Brake pedal pulsing UncLarryWasRight Wheels, Tires, Suspension 3 06 Jun 2008 06:12 am
