GT CLutch pedal adjustment
Like Tree2Likes
  • 1 Post By rob342
  • 1 Post By VNT
Old 12 Oct 2012, 07:45 am
VNT's Avatar
VNT VNT is offline
Default GT CLutch pedal adjustment
GT Clutch pedal adjustment
I am attempting to upload a copied pic of the adjustment for the clutch pedal, wont work
Anyhow there is a rod form the master cylinder which mates to an adjuster on the pedal, looks like you loosen a bolt and can lenghthen or shorten the amount of lenght the rod has where it attaches to the pedal.
When one pushes the pedal down the master cylinder rod pulls away from the firewall. If the pedal travels too close the floor for clutch disengagement I assume to reduce the pedal travel one would loosen the screw, and pull the rod forther out and then tourque the screw down.
My wifes GT seems to me to disengage much closer to the floor then my 05 and I want to adjust it.
Anyone done it?
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 12 Oct 2012, 10:07 am
Default Re: GT CLutch pedal adjustment
lots of us adjust it. loosen the 5/16" bolt, press the rod in and the pedal up, then tighten.
Stiff transmission when hot?
Old 12 Oct 2012, 10:36 am
VNT's Avatar
VNT VNT is offline
So to be clear, push the adjusting rod back toward the firewall, where you mean in and lift clutch pedal as high as possible?
VNT
Old 12 Oct 2012, 10:55 am
lol. you worded that as bad as i did!
sorry..
after you loosen it, lift the pedal towards the back of the car, and push the rod on the firewall towards the engine. (spread it longer)
VNT likes this.
Old 12 Oct 2012, 05:48 pm
VNT's Avatar
VNT VNT is offline
Gave it a quick adjustment, loosened it, lifted the pedal up and tightened it, now it has the same pedal feel as my other car and grabs higher off the floor!
Rob342, Thank You!
rob342 likes this.
VNT
Old 19 Nov 2016, 04:07 am
Same problem, thought about all that money I would be spending on a new clutch and related parts! Now, after a simple adjustment, it works much much better.
I am still have a bit of trouble shifting in to reverse, but nothing like before. I sure hope this forum stays alive long after our beloved PTs were killed by Chrysler.
Many thanks!
PT clutch pedal ass'y 1972cudaguy Classifieds: For Sale/Trade 2 25 Mar 2012 05:12 pm
clutch pedal play in 2006 5-spd melluna Tech & Performance Forum 1 05 Sep 2010 05:23 pm
Photo of clutch adjustment bolt? Dirk_Gently Tech & Performance Forum 1 25 Sep 2008 06:37 pm
???Clutch pedal adjustment??? Ctown General PT Cruiser Discussions 5 28 Feb 2005 09:08 pm
locking clutch pedal ...(?!!) raphael Tech & Performance Forum 1 14 Jan 2003 01:03 pm
