2004 PT GT Pilot Bearing/Bushing?
Old 12 Oct 2012, 03:48 pm
Default 2004 PT GT Pilot Bearing/Bushing?
I'm planing on doing a clutch job on my mom's 2004 PT GT this weekend, I ordered a clutch kit (press plate, clutch disk, slave cylinder) but can't seem to find a pilot bearing or bushing anywhere.
I've called parts store after parts store and a couple of dodge houses and eveyone after 5 minutes of looking says they dont show that it has one.
Has anyone had there PT apart?
What the hell does the tranny input shaft ride on? A bearing, a bushing or sum magical fairy dust?
Input is greatly apreciated
Old 12 Oct 2012, 05:19 pm
Default Re: 2004 PT GT Pilot Bearing/Bushing?
if you ordered the correct part, you'll be changing 1 big piece that is riveted together, and a throwout bearing.. nevermind. mine is non-turbo
Old 12 Oct 2012, 05:52 pm
VNT's Avatar
VNT VNT is offline
Download the parts manual here, no pilot bearing
Online Parts Manual's 2001 - 2007
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 12 Oct 2012, 08:25 pm
UptownSport's Avatar
This transmission doesn't need a pilot bearing.
In olden days, the input and output shaft were on the same axis, but would turn separately.
This required a pilot bearing as the input only had one bearing to support it in the middle:
(Right about where watermark is on this random google image)
Neat to note; when you engage "high", NO gears are working, the inputs and outputs simply couple together for 'direct'!
Now, the T-350 uses an input shaft supported on both ends.
Everything outside bellhousing is a twisting motion, there's absolutely no need to support end of input shaft.
You COULD install a pilot bearing, you'd need to ream input shaft and press in a small extension, then turn a chunk of oilite for the bushing.
Except there's no need, there's never problems reported with input shaft unless you're putting out power beyond reality.
Old 13 Oct 2012, 12:47 am
Lightbulb Re: 2004 PT GT Pilot Bearing/Bushing?
Thanks for all the feed back and drop'n the knowlage on me, it is greatly apreciated.
Seeing the pilot bearing shaft and the T-350 shaft helped ma brain alot.
Ive done a handfull of clutches in my day and cant ever remember seeing one without a pilot bearing or bushing of some sort (1 FWD & the rest were RWD)
I do have a couple of more questions-
1. Is this a common acurance on late model FWD MTX (no pilot bearing but supported internaly with bearings)?
2. Is the T-350 the PT GT (turbo) tranny and the GET288 the NA PT tranny?
Once again thanks to all of y'all
Old 13 Oct 2012, 02:36 am
1. Dunno. Previous family (for 2.2/2.5) didn't have a pilot bearing
2. Opposite, t-350 N/A and Getrag PT 2.4 turbo
Old 13 Oct 2012, 01:32 pm
I think your right about the FWD's no pilot bearing thing, Our 92 Tercel has no pilot bearing. It was news to me, I had ordered a clutch kit and it did not have a pilot bearing, so I went to the dealer and they said "nope does not have one"
so yeah maybe it's a FWD thing?
Old 13 Oct 2012, 01:55 pm
i've changed clutches on a few honda civics. they have pilot bearings
Old 13 Oct 2012, 09:31 pm
xwing777's Avatar
I doing a big build up right now on my 03' and recently pulled the trans out. No bushing and the turbo is the 288 getragg.
Couple of tips. Make sure you have a very short 6-point 18mm socket OR boxed wrench to remove the flywheel bolts. They are very close to the oil pan and not much room. You should replace these bolts as well ($2+ each from dealer and theres 4 of them).
Odds are you will need the flywheel re-surfaced as mine had hot spots. I too used to work on a lot of older rwd setups and i was confused at the flexplate-flywheel-pressure plate setup these cars have.
You can get the transmission out first and then remove the 4 bolts from flexplate which will drop the flywheel/clutch/pressure plate assembly but it is very, very tight. Its much easier to remove the 4 bolts first then remove the trans and pressure plate assembly together.
A few pics to help you see what your going to see:
Tags
clutch, fairy dust, naked, pilot bearing, transmission
Bushing kit dadjmon Wheels, Tires, Suspension 7 23 Jul 2011 07:06 am
Pilot Windshield Nozzles??? Teekypt Exterior Accessories Forum 13 21 Jan 2009 03:09 pm
Pilot Motorsports Windshield Wipers??? Teekypt Exterior Accessories Forum 11 24 Jun 2008 10:45 pm
bushing install 4SPEED Wheels, Tires, Suspension 1 26 Sep 2006 06:30 pm
Control Arm Bushing PTZCrazy Wheels, Tires, Suspension 6 08 Jun 2004 02:42 pm
