How Long Can You Drive On A Bad Front Wheel Bearing?
Like Tree9Likes
Old 12 Oct 2012, 04:00 pm
Default How Long Can You Drive On A Bad Front Wheel Bearing?
I have a friend with a 2002 PT and the passenger side front wheel bearing is grinding away quite loudly.
They will not have the money to replace it for another 20 to 30 days.
How long can they drive the car like this and what else might happen if it does not get changed soon enough?
Thanks
Old 12 Oct 2012, 04:20 pm
Default Re: How Long Can You Drive On A Bad Front Wheel Bearing?
Tell your friends, until the wheel falls off.
I'm going to miss those radio mechanicomics.
If the bearing is grinding loudly, drive only in the curb lane, and slow speeds.
Further possible damage can entail needing to replace the steering knuckle and/or hub.
Park it or borrow money from parents like Romney says. Don't be a 47-er.
Thanks
Old 12 Oct 2012, 08:32 pm
UptownSport's Avatar
I had one that lasted forever, but was so loud that I had to wear earplugs.
I ground it apart, and there was only some flaking on the race- It was in no risk of catastrophic failure.
Old 12 Oct 2012, 08:49 pm
cruisin03pt's Avatar
The best way to think about it is like this: Say your knee cap is old and worn out. Its painful to walk on it, It also does a crap-ton of damage to your joints. Same thing aplies here. Normally the ABS light will come on first, telling you to look at the hub. Sometimes, it may be nothin. But sometimes its something a whole hell of a lot worse. It's common sense man, Park it or expect to be replacing more than just the bearing. Also, tell them to buy a quality bearing/hub assembly. You get what you pay for. The better bearings have a much better warranty policy, and are generally(not always) made of a better wearing material. If i had to suggest, BCA(national) makes a really good bearing for the money. I think in the year and a half ive been selling them, i've had one come back on a warranty. That's just my 2 cents.
If they have HAVE to use it, Only drive a very short distance. Anything more, you're just asking for trouble.
Old 13 Oct 2012, 12:44 am
Is this a trick question?
If it is on fact bad, for the safety of who ever is driving along with other driving around you, you don't continue to drive it!
Old 13 Oct 2012, 08:29 pm
Thanks for all the input cruisers
I will pass the information on to my friend.
Old 14 Oct 2012, 07:52 am
My son drove his until the bearing disintegrated and then the spindle started eating the whole hub. He finally "noticed when the hub got so eaten that the strut tower hit the tire and prevented the car from moving. ( The hub was keyholed a good 1.5" when they looked at it!)
Point being that it might be better to put the wheel bearing job on a CC than to wait till it's a $700 job plus a tow. Been there- Done that.
Old 14 Oct 2012, 09:53 am
How long did he drive on it before the hub got eaten?
Old 14 Oct 2012, 10:09 am
bob2006...he said his son drove it un-noticed until other things began failing. lol
Old 14 Oct 2012, 10:58 am
It won't likely fall off. That said as posted above If you keep driving it will tear up a lot more stuff and could puncture a tire if you get as bad as the boy in the earlier post and that could cause you them to wreck. Could take a day or a month. It's a crap shoot. Let their wallet decide if the risk is worth it!
How to tell which front wheel bearing is bad? sscanlan Tech & Performance Forum 21 13 Dec 2011 11:06 pm
2001 Front Wheel Bearing and Hub azuretech Wheels, Tires, Suspension 6 19 Jul 2011 06:01 pm
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
Front Hub & Wheel bearing JoeHundredAire Wheels, Tires, Suspension 2 15 Jun 2008 11:25 am
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
