Problem with hitch wiring
Old 15 Oct 2012, 12:07 pm
Default Problem with hitch wiring
Installed a Curt trailer hitch with the included wiring harness.
My driver side rear lights do not turn on when I turn my lights on at night, unless I step on the brakes.
Everything is plugged in properly and isnt loose.
As soon as I unplug the harness and plug the original harness back into the light it works but my trailer light does not.
Old 15 Oct 2012, 12:15 pm
cruserdad1976's Avatar
Default Re: Problem with hitch wiring
did you check the bluls in the trailer??? if not its a bad harness maybe trace the wire or get a diffren one
Old 15 Oct 2012, 12:43 pm
I checked the bulbs on the trailer. They work perfectly when the harness is plugged into the car harness.
The problem is that when the trailer is not attached, the driver rear light does not turn on when I turn my lights on; unless i step on the brake. Then it lights up.
Old 15 Oct 2012, 12:44 pm
The harness cant be bad b/c it works all lights. Just not the lights of the car and the trailer at the same time.
wiring up switch for fogs, ran into problem. jrbsr05pt Exterior Accessories Forum 3 03 Jun 2012 09:20 pm
Trailer Wiring Harness Problem captspaulding General PT Cruiser Discussions 4 11 Jan 2012 06:11 pm
transmission internal wiring problem??? dcrider81 Tech & Performance Forum 13 14 Aug 2009 12:51 pm
trailer hitch wiring barold Tech & Performance Forum 8 10 Jan 2008 01:42 am
PT Cruiser Trailer Hitch and wiring harness skinnyside Classifieds: For Sale/Trade 2 13 Dec 2007 09:56 pm
