heater blower problems
Old 21 Oct 2012, 11:05 pm
Default heater blower problems
My wife's 2001 Limited Edition Cruiser is having problems with the heater blower fan working erratically. When cold, the blower really puts out the air but sometimes it slows more and more until it stops. Sometimes, turning the control right off for a minute will "reset" the blower and it will then work fine. Thanks in advance for any help.
Old 22 Oct 2012, 02:16 am
podo2000's Avatar
Default Re: heater blower problems
Might want ti check the intake under the passenger footwell. Mine did that till i found a piece of plastic getting sucked in there slowing airflow.
Old 22 Oct 2012, 02:25 pm
Now, THAT would explain a lot. Will have a go at that tomorrow and post the results here. Thanks for the tip!
Old 22 Oct 2012, 04:27 pm
I have another suggestion if you don't find anything. There's a low pressure switch on top of the accumulator (see pic) it's also called the recycling switch. This switch controls the on/off sequence of the compressor. You say it only does this when it's cold and your running the A/C. If that switch is malfunctioning, the compressor won't turn on and off like it's supposed to. It only stays ON. After awhile, things get so cold it freezes up and stops the flow of cold air into the cabin. The only way to unfreeze it is to shut it off (like your doing) so it can defrost or turn the control to heat ....not good in the summer. All it takes is to unscrew the old switch, screw in the new one and every things fine again. I know first hand and when putting in the new switch, there's a tiny "O" ring on the threads. Screw the new switch on too tight and the "O" ring splits. That's also happened when I replaced mine.
............Heater Problems.............. fatboypt Tech & Performance Forum 1 16 Jan 2012 10:34 pm
Heater Blower Motor Issue sscanlan General PT Cruiser Discussions 5 30 Aug 2011 10:50 pm
Rain Water in heater blower motor markf497 Tech & Performance Forum 12 17 Jul 2010 02:38 pm
Blower Heater Problem Phewzd Tech & Performance Forum 1 14 Jan 2009 02:45 pm
Drying with a leaf blower=problems? Pat1USMC The Detail Shop 7 23 Apr 2004 11:41 am
