New here need help
Old 23 Oct 2012, 10:06 pm
Default New here need help
My fan motor is not working when I turn on my A C
AC works if I drive fast
Can anybody tell me where is my high low end ( not sure what's call)
The one that cools your AC
How do I fix this problem
Thanks! Sorry if I don't explain it right I'm bugled right now
Somebody help
Old 23 Oct 2012, 10:26 pm
Default Re: New here need help
Somebody help
I had the same problem twice.
First it was a failure in the fan itself, it would only operate on "low"and second it was a fault in the wiring, a combination of a loose connection/abraded wire.
I replaced the fan first and then used a continuity checker to find the fault in the wiring and repaired that.
Old 23 Oct 2012, 11:35 pm
Hmm...I think what your saying ..is that, when you turn the control to AC and turn the fan on there is no air movement?
Old 26 Oct 2012, 03:12 pm
mdfrodolives's Avatar
If you're talking about the radiator fan (which also cools your A/C condenser), then you simply need a new radiator fan.
Tim
Old 26 Oct 2012, 03:14 pm
cruserdad1976's Avatar
rock auto has new fans some have rebuilt theres or replaced relays my i just replaced the whole fan they are about $90 if you dont do something you WILL overheat the motor
Old 26 Oct 2012, 04:48 pm
I thought he was talking about the interior fan?
