Power Management Center Issue
Old 19 Nov 2012, 01:36 pm
Default Power Management Center Issue
I am having an occasional starting problem with my 2004 PT. It turns over but will not start BUT if I tap the top of the power management center it will then fire up. I replaced the fuel pump relay but that does not seem to make any difference. Could there be a wiring issue on the underside of the PMC? If so how do I remove it to check and is it repairable?
Thanks in advance for your advice.
Doug
Fuse for Cigarette Lighter under hood in power control center oldorange General PT Cruiser Discussions 4 08 Jun 2014 08:51 pm
Removing Center Console Power Outlet moonstone Tech & Performance Forum 2 19 Dec 2011 02:49 pm
2008 Power Distribution Center Teknoron67 General PT Cruiser Discussions 1 10 Oct 2011 02:59 pm
power window issue djd General PT Cruiser Discussions 6 14 Feb 2010 12:40 pm
Center console power outlet jimmirehman Interior Accessories Forum 13 02 Sep 2007 11:45 pm
