Oil leak.
Old 19 Nov 2012, 05:48 pm
Cool Oil leak.
I have a 2004 PT Turbo with 30k miles on it and just noticed an oil leak. I have no lift so I felt around down around the inside of the front bumper cover. It fees like the leak is coming from a line that runs into what I assume is the oil cooler behind the radiator. It is not tranny fluid (wrong color, wrong smell). The leak stops when the engine reaches normal operating temperature. Anyone heard of this before?
David
Old 19 Nov 2012, 06:08 pm
cruserdad1976's Avatar
Default Re: Oil leak.
well imn not a turbo guy but i belive that is the inter cooler im not sure why it would ahve oil going to it but i guess it could
Old 19 Nov 2012, 06:30 pm
There is a trans cooler and the power steering is run through the radiator.
Old 20 Nov 2012, 12:22 am
I had a leak in that area, it cost me $1.49 to fix it.
The factory "crimp-on" hose clamp was loose where the power steering hose goes into the radiator. It was a royal PITA to get the old one off, I had to grind it down with a Dremel until I could break it loose.
Then I just replaced it with a standard screw-type hose clamp. Never even had to remove the hose from the radiator barb, so no muss, no fuss, at least with fluid.
Old 20 Nov 2012, 01:06 pm
chris15's Avatar
If it's a manual, no trans cooler. Need more info.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 20 Nov 2012, 01:54 pm
Okay,
After more investigation, it looks like it's the p/s fluid that's been leaking. Until I can get it on a lift, I'll just top off the fluid. Any recommendations on fluid type?
Old 20 Nov 2012, 02:52 pm
chris15's Avatar
If you're planning to have the system flushed and the leak fixed, you could roll the dice on those fancy stop-leak concoctions.. But I'd only do that if you're planning to have it flushed. Otherwise, just top it off until you can fix the leak. I believe there was a TSB issued that called for the fluid to be replaced with ATF-4.
Old 20 Nov 2012, 07:39 pm
Yep, ATF-4
I used the stuff they have at O'Reilly's
bad oil leak naford302 General PT Cruiser Discussions 19 12 Sep 2017 06:41 am
07 PT with Oil Leak jstcuz Tech & Performance Forum 14 10 May 2012 01:03 pm
oil leak Nickatnite Tech & Performance Forum 10 11 Oct 2011 08:45 pm
ATF Leak shlalk General PT Cruiser Discussions 12 24 Mar 2004 09:05 am
First Oil Leak? Ack! beebs General PT Cruiser Discussions 4 18 Oct 2003 10:55 am
