burning oil?
Like Tree2Likes
Old 19 Nov 2012, 10:09 pm
Default burning oil?
so im looking at geting a pt. but ive heard they burn thru oil. such as using a quart of oil every 250-500 miles. does anyone hve this problem and is this a problem with pt's?
Old 19 Nov 2012, 10:28 pm
Default Re: burning oil?
Look around at the ones you see on the road If you don't see a huge cloud of smoke. Then you will know the people you been talking to are the ones blowing smoke.
Badglas likes this.
Old 20 Nov 2012, 12:38 am
compdr59's Avatar
126K and I go 8k between changes w/o adding oil.
Original Owner 135k
Old 20 Nov 2012, 02:08 am
podo2000's Avatar
114Kmiles and i go 7,500 miles between oil changes. Never had to add oil in between changes.
2005 Limited ed
Old 20 Nov 2012, 06:02 am
110+K, go 5,000 miles between changes, use no oil.
Old 20 Nov 2012, 08:32 am
i have a heavy foot, 248k miles...
....mine don't burn, it leaks (:
Old 20 Nov 2012, 01:05 pm
chris15's Avatar
Uh, honestly.. that's not really a make-specific trait that you could attach to the PT brand.. some cars are known for bad head gaskets and other issues, but the only correlation between 'burning oil' and owning a PT is poor maintenance and bad owners (either previously or currently).
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 20 Nov 2012, 08:13 pm
UptownSport's Avatar
No, these are very good on oil consumption.
Old 21 Nov 2012, 12:25 am
cruserdad1976's Avatar
120,000+ change oil ever 4000 never have added oil and mine is mostly running 70-80 so id say BUSTED on the 250-500 miles theory
Busted_PT likes this.
Old 21 Nov 2012, 07:09 pm
I work at a dealer, and I honestly have never seen a PT that was burning oil.
The only major engine problem I've seen is on a few 2007 models with between 30-50k miles, the crankshaft started walking back and forth and blew out the main seals, requiring engine overhaul/replacement.
But even then, with the hundreds of PTs I've been around over the years, there have only been a few with that crankshaft problem, so it's rare to say the least.
-Chris
VIN burning on stock used pcm sylster Canada PT Forum 17 20 May 2011 12:08 am
Help with burning CD's gangstajoshua Sound and Security Forum 10 19 Apr 2011 11:45 pm
Oil Burning ChadTottingham Tech & Performance Forum 5 11 Jan 2011 05:16 pm
Burning 1 Qt. oil every 2K on '06 w/ 37K???? 66CUDA Tech & Performance Forum 11 14 Mar 2010 09:40 am
Odor of burning wood wearl50 Tech & Performance Forum 12 14 Mar 2004 04:16 am
