Starting Issues
Old 20 Nov 2012, 05:34 pm
Default Starting Issues
03 Base. Last week my wife called to tell me that the car would not start but it turned over. I got there and it started with the key normally. This morning it did the same thing, it will not start. I plugged the block heater and battery blanket since 8:30 this morning and still will not start.
The car will turn over and I will get the rumble that she is going to go for a second but nothing happens. The starter will continue to crank but I will not get the rumble again unless I kill and restart the start sequence. I tried starting with my portable battery booster but no help.
Old 21 Nov 2012, 11:00 am
Default Re: Starting Issues
Did check for codes with OBDII and came back with P0700 and P0562. It's too cold at the moment, about -20F, so I will just wait 'til it warms up a little (in the spring ) before I tinker with it. Will 562 make it not start? I checked for codes last summer and there were none so those codes were recent.
But feel free to suggest what I have to check . I am suspecting fuel pump.
Old 21 Nov 2012, 01:22 pm
as far as the p0562 check this:
OBD2 - OBDII Code P0562 DODGE - System Voltage Low | Engine-Codes.com
and the p0700:
http://engine-codes.com/p0700_chrysler.html
Old 21 Nov 2012, 02:13 pm
Yep, I was there last night. Thanks.
Old 21 Nov 2012, 02:56 pm
depending on the age of the battery, i would replace that first.
Old 22 Nov 2012, 11:06 am
One of the battery posts was dirty so that got cleaned and due for replacement soon. I may have tried to start it too many times and I pulled the plugs and they were wet with fuel. Cleaned that and put back, she started. Drove around the town, tried starting it again after and she started just fine. I had to bring her in buddy's garage to work on it.
This morning, which is colder than the other day, PT would not start again. I am now guessing it is cold weather related. I hope to find out soon.
Old 22 Nov 2012, 11:42 am
I'm with soyomb, cold weather eats batteries. if you have a meter, see if the battery is up to around 11.8 volts when the engine is off. You need around that to get the engine going.
Old 23 Nov 2012, 05:26 pm
I've had a couple of batteries that went bad and usually it will give you the slow cranking as a sign that is about to go. None of that happened and when I checked the battery a couple of months ago it was good and production date was September 2009, which is fairly "new" considering the car has a battery blanket (wrapped around the battery and heats up when plugged in) and no issues when temps dipped down a week ago.
Just for the fun of it I hooked up my battery charger and it started when fully charged. Let it run for about 15 minutes. 2 hours later, when about to buy a new battery car would not start again. I boosted it up and she started.
New battery is installed and she started fine this morning. Hopefully there is no electrical issues that is draining the charge. I will find out when temps dip again in the next couple of days.
Thanks for all the help.
Old 23 Nov 2012, 06:19 pm
You had a dead cell. Had a Walmart battery with a weak cell charged up tested good at wally world. Left an drained the power and upon return it checked bad and they replaced it.
Starting issues ... *sigh* nickdel Tech & Performance Forum 20 07 Feb 2013 01:35 am
pt starting and driving issues 05pt_cruiser Tech & Performance Forum 0 16 Jan 2012 10:21 pm
Starting Issues Need Help!! 01 PT Manual cusunfireguy General PT Cruiser Discussions 8 31 Jan 2011 03:19 am
2006 PT starting issues thebriarman Tech & Performance Forum 5 25 Jul 2010 10:13 pm
2008 PT Starting Issues PTcruisinator Tech & Performance Forum 2 14 Jan 2010 08:25 pm
