01 pt wont start after head work
  • 1 Post By cruserdad1976
Old 25 Nov 2012, 10:12 am
Default 01 pt wont start after head work
new here...... i brought a 01 pt with a bad head do to an overheat
the head was resurfaced, checked and cleaned
put it back with the correct torque, correct timming marks
brand new crank sensor and cam shaft sensor
only one time fired up, now it looks like it want to start but nothings happend
it has good spark, it has good fuel but nothing....i have good knowledge in mechanic but first time time dealing with a pt and is a headache
please any suggestion would be apreciated......thanks
Old 25 Nov 2012, 10:25 am
Default Re: 01 pt wont start after head work
Lots of older posts to get you started. The only thing I'll add is that I hope you used genuine MOPAR sensors as the PT doesn't like the cheaper aftermarket sensors. They either don't work at all or don't last very long because of inferior, interior parts. They may look the same but aren't. Now, here's some of the other threads on starting problems.
One start Starters
Starting Issues
pt wont start
Car Wont start!!
PT Cruiser Won't Start
HELP 06 PT Cruiser not starting
Wont Start anymore....
My 2002 Cruiser won't start
New Owner - 2001 Cruiser - cannot start
Old 25 Nov 2012, 11:04 am
thanks for the reply, i've already check those threads and no one has the problem that i have......i dont know what else to do...this pt is driving me crazy....lol
Old 25 Nov 2012, 01:21 pm
UptownSport's Avatar
Cam sensor connector an Coil connector aren't mixed up?
Other wise, if it ran before it's cam timing
Old 25 Nov 2012, 06:27 pm
cruserdad1976's Avatar
like alread said byuptown if everything is hooked up the correct way it has to some how be related to the timing like 1 tooth off or 180 out
zamfir2 likes this.
power windows wont work edmundt Tech & Performance Forum 4 05 Sep 2012 12:47 pm
2001 PT Cruiser Radiator FAN WONT WORK AutoServWorks01 Tech & Performance Forum 12 20 Jul 2012 09:21 pm
i ran over my key at work tonight now my car wont start dbrockman Sound and Security Forum 5 17 Mar 2012 05:49 am
Tail lights wont work tjc General PT Cruiser Discussions 5 12 Oct 2011 02:46 pm
Headlights wont turn on but highbeams work uhhmm ok invidious Tech & Performance Forum 4 08 Jun 2009 11:25 pm
