Check Engine Light -- Cruise Control
Old 25 Nov 2012, 02:03 pm
Default Check Engine Light -- Cruise Control
The instant that I turned on the cruise control yesterday, the check engine light came on. There was no apparent effect. The cruise control worked, and we've continued driving the car.
However, we would like to know if there might be a problem that should be looked into right away.
Old 25 Nov 2012, 02:14 pm
Default Re: Check Engine Light -- Cruise Control
Would guess the speed sensor. You will need to check to see what codes were stored in the computer from that.
Old 25 Nov 2012, 02:19 pm
If the CEL (Check Engine Light) came on, as Busted said, the computer most probably set a fault code. Use the instructions below to get the code and come back to the forum.
How to retrieve fault codes.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Engine light on, cruise control off. snateman Tech & Performance Forum 3 23 Sep 2010 12:30 pm
