2003 pt crusier
Old 27 Nov 2012, 01:21 pm
Default 2003 pt crusier
can anyone help me out on what is up with my 2003 Pt crusier ..the diagnostic read multiple misfire in cylinders.. and it is dying when i come to the a stop and will not go over 50 mph..
Old 27 Nov 2012, 01:33 pm
Default Re: 2003 pt crusier
When was last time Wires & plugs were changed?
Old 27 Nov 2012, 04:02 pm
Although the coil is a strong point in the ignition system, you could have a problem with it.
Also:
Fault Code P0300 - Multiple Cylinder Misfire
A misfire code in a specific cylinder (P0301-Cylinder #1, P0302- Cylinder #2, etc.) usually indicates a possible problem with a plug or ignition wire. A P0300 code indicates the misfire is random and moving around from cylinder to cylinder. The cause here would likely be something that upsets the engine's air/fuel mixture, such as a major vacuum leak, leaky EGR valve or unusually low fuel pressure (weak pump or faulty regulator).
Old 27 Nov 2012, 06:07 pm
All of the above! It could also be a flakey cam sensor, although usually you get a specific code for that. Do the above first.
Hello New Crusier Here mystynm Welcome New PT Cruiser Members 12 06 Apr 2012 07:06 am
Rims for PT Crusier - 2003 Chrome wingodsays Wheels, Tires, Suspension 1 27 Jun 2011 11:33 am
Another new Crusier CruzinCajun Welcome New PT Cruiser Members 9 29 Apr 2011 02:16 pm
2003 pt crusier wont start smith4384 General PT Cruiser Discussions 4 19 Jan 2009 02:27 pm
BAD PT Crusier day Samurai General PT Cruiser Discussions 4 08 May 2006 02:54 pm
