Power Heated Mirrors Addition
Old 01 Dec 2012, 11:52 am
VNT's Avatar
VNT VNT is offline
Default Power Heated Mirrors Addition
I went yarding and raped a 2001 Limited
Snagged the pair of heated power mirrors. Also grabbed the door harness connector/pigtail.
Anyhow I want to add these to my 03 GT, which has power mirrors but they dont have the defrost feature.
I am hoping Chrysler just deleted the feature in the mirrors and ran the same harness to the doors so this would be a plug and play.
Anyone add pwr heated mirrors into on with pwr mirrors?
I see on the other thread folks adding them to the base models.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 01 Dec 2012, 04:05 pm
sanatanadharma's Avatar
Default Re: Power Heated Mirrors Addition
Probably not plug and play. Check the door mirror connectors; the heat function will have a lite blue/yellow wire at pin #3.
My 2004 base (manual mirrors) had the necessary connectors for the power mirrors and mirror switch. Adding the power mirrors was simple (did need to replace lower left dash panel for switch).
The heated mirror function, however, required running wires to the connectors in the door. I choose to duplicate the oem wiring using the rear window defogger switch and adding the needed fuse-box and C204 & C205 connectors.
The heat function could be made operable by tapping any power source (I'd suggest an ignition switch controlled circuit and fuse) and adding any switch of your choice.
Posting in stealth will not be permitted in most threads please read the forum guidelines.
Heated Mirrors? lmnopq General PT Cruiser Discussions 2 12 Apr 2011 01:30 am
heated mirrors.... rockrtboy General PT Cruiser Discussions 4 09 Jun 2006 09:10 am
Heated Power Mirrors crazyjoe Exterior & Interior Styling 5 15 Nov 2003 12:59 am
Heated Mirrors WAYNEF General PT Cruiser Discussions 8 04 Sep 2003 12:27 am
Heated mirrors. iownacruiser Tech & Performance Forum 2 26 Apr 2003 01:54 pm
