Brake Lights keep fusing
Old 09 Dec 2012, 07:46 am
Default Brake Lights keep fusing
Hi, Just picked up a 51 PT Cruiser LE and the brake lights aren't working. Check to fuse in the engine and it's blown. Replaced it. Blown again.
History... A tow bar was fitted and the connections were made to the lights at the RHS, I've disconnected that now, but still blows fuses.
Any other suggestions were I could look next at other known points where there maybe a earthing fault?
Old 09 Dec 2012, 07:50 am
Default Re: Brake Lights keep fusing
There's NO known faults with the PT Cruiser lights. After saying that, check for moisture inside the lights themselves. If no moisture, what you have is someone that hooked up the tow bar and screwed things up electrically. You might have to start from scratch and pull all the wires from the bar and test the wires on the car with a multi-meter before slowly putting it all back together.
Brake lights wont work, 3rd brake does Dill General PT Cruiser Discussions 17 03 Oct 2016 04:34 pm
Brake Lights out? Plz help! CruzinPT Tech & Performance Forum 5 18 Dec 2010 02:11 pm
HELP! '02 Cruiser with no tail lights, then no brake lights. tschauer Tech & Performance Forum 1 16 Sep 2010 05:54 am
Why do my tail lights and dashboard lights only go on when I brake? bodykits Exterior Accessories Forum 1 16 May 2009 07:28 am
No Brake Lights iziris General PT Cruiser Discussions 2 18 Oct 2007 01:42 pm
