How do you pull PT Cruiser out of the snow
Like Tree2Likes
  • 2 Post By Busted_PT
Old 13 Dec 2012, 01:31 am
Default How do you pull PT Cruiser out of the snow
I'm in Minnesota , it's not if, its when it gets stuck in the snow, how do you pull it out, what do you hook to in the front and rear of My PT Cruiser, it's a 2003.
Old 13 Dec 2012, 04:52 am
Default Re: How do you pull PT Cruiser out of the snow
That's a real good question...been thinking the same thing myself...so far, my solution has been driving the Jeep in the snow. There was talk on this forum a little while ago about a detachable so-called "tow hook" found on the front of some PTs (European models perhaps) but it looked like a glorified eyebolt and not substantial enough to use as a recovery point. On my PT, there is a bracket bolted on the rear but it probably is intended as a tie down point for use during transport and again not intended for recovery. Been thinking about fabricating something but haven't come up with a answer yet. Safety is the biggest issue here...hooking to the wrong place can damage the vehicle or turn the attach point into a missile if it lets go.
Old 13 Dec 2012, 06:16 am
Teska's Avatar
So how bad is it with the snowfall where you are ? Cause to me that looks like a silly question. Here in Belgium worst case we have 15" of snow, but with my snowtyres I will get away anytime.
Moreso, two winters ago I pulled out of the worst snow conditions ever in my live, on summer tyres and with the help of my Honda Civic's traction controll.
PT Cruiser 05 base 1,6 liter Electric blue.
Natural gas system build in.
Lowered with FK coilovers.
Installed Mopar sub !
Old 13 Dec 2012, 11:17 am
2step's Avatar
It seems that in some European countries tow hooks (tow eyes?) are required to be included by the manufacturer........
Tow hook question
Apparently that's not the case in the USA.
Old 13 Dec 2012, 11:59 am
I use the rear axle haha but i have a straight axle, without independent suspension etc. so.
Old 13 Dec 2012, 12:03 pm
The rear tie down is more than capable to pull you out if you are cleared out behind you before you start. Also pull straight back not sideways. In front there is nothing. The only substantially strong peace is the main cross member. Where all the suspention is connected to. Be hard to get to if you're stuck.
Old 13 Dec 2012, 12:11 pm
cant forget the control arms!
Downside- be prepared to replace your bushings, and ball joints later that day :-D but it works in an emergency haha :-p
Old 13 Dec 2012, 03:45 pm
that is the only place i'll hook it in front..
what is the rear tie down? when i googled it all i could find was this: " One involved a PT Cruiser that was buried up to the floor boards in snow. I was in the old Chevy truck in my snow vid. The only way I could latch on was to drive around behind them (they did a lazy 180 and dropped in the ditch backwards), hook the tow strap to the rear tie down point and drag them out by going FURTHER in the ditch, then out again. In the process I bent the living **** out of that tie down point. They weren't THAT concerned about it, but they did kind of freak out."
Old 13 Dec 2012, 06:15 pm
This is the tie down. As you can see pulling sideways would easily bend this but a straight on pull would be OK.
mityqwik and rob342 like this.
PT Cruiser pull "cargo" trailer Cruiszr General PT Cruiser Discussions 2 06 Apr 2012 09:24 pm
Boat Pull? Jimmy2011 General Turbo Discussions 5 06 Oct 2011 06:12 pm
Weird Pull ejschultz Tech & Performance Forum 13 19 Nov 2009 11:09 am
Dunlop 15" Snow Tire Alloy Wheel Pkg-Better PT Cruiser Winter Handling - $700 arupprec craigslist 5 31 Dec 2008 06:03 pm
PT Cruiser Snow Drift skylight PT Cruiser Videos 0 13 Dec 2007 08:03 pm
