weird issue
Old 13 Dec 2012, 03:12 pm
Johns03PT's Avatar
Default weird issue
i dont know if this is a common problem but it started up bout 3 weeks ago... started it up like normal, ok good. i go to press the gas down, my brake light pops on, i continue to accelerate, when i let go of the gas the light turns off. this happens quite often now. any ideas?? im guessing its a short.
2003 Pt Cruiser base model....Mods coming soon!!
Old 13 Dec 2012, 03:23 pm
Default Re: weird issue
Old 13 Dec 2012, 03:25 pm
what brake light? the one on the dash? or the tail lights?
if it's the one on the dash, check your brake fluid. as the pads wear the fluid level gets lower.
Old 13 Dec 2012, 03:45 pm
i agree with rob. and if that doesn't work, check the wiring to the brakelight switch. it's right next to the gas pedal and if the harness somehow dislodged itself, it may be hanging in the general area.
2016 Kia Soul Plus Black
Old 13 Dec 2012, 04:02 pm
Johns03PT's Avatar
yes its the one on the dash, ill take a look at everything and let u know what it was. thanks for the tips
Old 14 Dec 2012, 08:15 pm
Matt42's Avatar
What he said. This exact thing has happened to my PTs. As the brake pads wore, the fluid level in the master cylinder reservoir moved into the caliper cylinders. The fluid in the reservoir sloshes on acceleration. Adding a few CCs of brake fluid turns off the light.
The problem, such as it is, is more likely to show up in models with four wheel disc models.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
03 GT trans issue...weird one CrewChief Tech & Performance Forum 18 26 Aug 2012 06:22 pm
weird a/c issue bogie2929 Tech & Performance Forum 2 05 Aug 2012 09:54 am
Weird Cooling Issue TurboDucky Tech & Performance Forum 3 31 Dec 2011 01:40 pm
Weird Foglight Issue... derek02PT Tech & Performance Forum 2 07 Aug 2011 02:52 pm
Weird issue Opiate General PT Cruiser Discussions 4 09 Aug 2008 10:05 pm
