Broke plastic tube/hose when removing throttle body
Old 13 Dec 2012, 08:15 pm
Default Broke plastic tube/hose when removing throttle body
I was removing the throttle body tonight on my 2006 pt cruiser, and broke a plastic hose in the process. It is the hose that attaches to the metal nipple on top of the throttle body. It goes back towards the firewall and then down, I can't see where it ends. I did a couple of quick searches, but can't find anything that definitively says what this hose is. It looks like maybe it would be a purge hose?
Can anyone tell me for sure what this is, and how far I need to go to fix it? If I can just put the two pieces back together and put a piece of rubber hose around the break to hold them together, will that be ok, or do I need to find a replacement somewhere?
Old 13 Dec 2012, 09:18 pm
sanatanadharma's Avatar
Default Re: Broke plastic tube/hose when removing throttle body
It is the line from the purge solenoid to the throttle body. The purge solenoid is mounted low on the driver's side of the firewall, below the brake vacuum boost. Yes, you could likely fix it with a piece of appropriate size hose and a couple of clamps.
Old 13 Dec 2012, 09:49 pm
Thanks!
Broke oil dip stick tube DODGETHIS Tech & Performance Forum 10 03 Apr 2012 03:03 pm
AIr filter box to throttle body coupling hose sscanlan Classifieds: Want To Buy 7 03 Dec 2011 03:40 pm
wtb 05-up upper intake manifold, throttle body, intake hose to turbo,aircleanor lid 1autodr Classifieds: Want To Buy 1 24 Feb 2011 05:15 pm
Engine Oil dipstick handle broke off in tube Samson General PT Cruiser Discussions 8 13 Nov 2010 09:39 pm
Molded Emmission hose/tube for '03 GT??? ChicagoPT Tech & Performance Forum 9 21 Apr 2009 07:03 pm
